3rd Gen Durango 2011+ models
DIY driverside headlight change Durango 3rd Edition 2014 Limited
Old Jan 9, 2017 | 11:34 AM
birdbird223's Avatar
birdbird223
Default DIY driverside headlight change Durango 3rd Edition 2014 Limited
Hey gang, anyone with a 2014 or newer had to chage their headlightds themselves? I searched online and can't find the proper fix. ONce says to go in through the filter box under the hood...another says go under the wheel area and go in from the bottom. ANyone have a link or somehting that may be helpful? Thanks in advance!!!
Old Jan 9, 2017 | 12:23 PM
https://dodgeforum.com/forum/3rd-gen...t-removal.html
Old Jan 9, 2017 | 01:23 PM
SHO Rod's Avatar
SHO Rod
Are you looking to replace the entire headlamp assembly, or just the bulb?
-Rod
Old Jan 9, 2017 | 02:10 PM
oharag's Avatar
oharag
-Rod
Crimeny
I hope it's easy to replace just the bulb rather than the whole assembly. I clicked on the link above and nearly pooped myself. I had the right turn signal bulb replaced recently by dealer. Figured it was easier that way. Though I would like to replace my front headlight bulbs when they go bad. On my Nissan it was a piece of cake. Reach into engine bay - quarter turn plastic nut - remove whole assy. twist out bulb - replace bulb and then quarter turn later you are done. Is this as easy on the Durango?
Old Jan 10, 2017 | 02:13 PM
coldsteel's Avatar
coldsteel
Do you have standard halogen bulbs or the factory self-leveling HID Xenon bulbs?
Old Jan 11, 2017 | 07:57 AM
SHO Rod's Avatar
SHO Rod
With the standard halogen (which I recently updated to LED bulbs) in my 2011 it's pretty easy. There's an access door in the wheel well liner that takes about a 1/4 turn to remove, then most people should be able to fit their hand and part of their arm in to the cavity to access the bulb.
-Rod
Old Jan 20, 2017 | 10:59 AM
birdbird223
Hey sorry for having such a late response, it's just to replace the bulb.
-Rod
Old Jan 20, 2017 | 11:01 AM
birdbird223
I believe it's time he standard bulb. The title name for it is 9012...if that helps.
Old Jan 20, 2017 | 11:07 AM
birdbird223
thanks jkeaton, I'm going to give this a shot this weekend,....finally lol
Old Jan 24, 2017 | 11:52 AM
HeMiDD305's Avatar
HeMiDD305
Just read your profile. I used to live in Ashburn, VA. HAHA
