Here We Go Again..DDRT'12 not starting..
Brought her in maybe 2 yrs ago for the whole fuel pump relay TSB. Knock on wood have not had issue since. Now within past 2 weeks truck has the classic cranking sound but not turning over. Popped fob into the ignition and it started but quickly sound like the truck was under water and ready to stall. Got out and used the auto start on fob and she fired up. Dealer says computer gave a code that key fob battery is low and faulty communication. Ok changed battery and did it again this weekend, wifey stuck at the bank with same issue for 20mins until she got it started. Now I use the spare fob today at my oil change place. My tech tells me same thing happened on start up and he also got a key fob code. Saying it's a safety feature where the truck is not sure it's suppose to be starting so not sending enough fuel for full ignition. The communication between the key and trucks computer are having a disconnect. Without referring to the old TIPM thread has anyone else run into this with fob issues? These things going bad?
Here's the thread I started on it:
https://dodgeforum.com/forum/3rd-gen...-not-tipm.html
My '12 Citadel has always had starting problems. Every once in a while it will stall and if you try to restart it just cranks and never catches until you shut it off. Then it will restart just fine. When it first stalls, if you shut it off it will then also restart. It happens intermittently, sometimes not for months.
I've never been able to find the the problem, nor has the dealer. It has never thrown a code.
I've alway suspected it was a bug in the security system- it thinks it was an unauthorized start and won't let it.
Is there a recall on the relays they added in the previous recall? Or did yours just fail? Did they charge you for the replacement?
I was just told the R09 recall needed to be re done do to failure. Had a convo with tech regarding it and he said a lot of people were running into same issue. They replaced it free of charge, and knock on wood I have had no start up issues since.
Trending Topics
Just waiting for the 2018 DD models to start showing up at the dealerships.
Look at, touch and then test drive.
