3rd Gen Durango 2011+ models
replace projector headlight with regular one?
Old Nov 13, 2017 | 08:55 PM
paul.slagel@icloud.com's Avatar
Default replace projector headlight with regular one?
I hit a bird and broke a projector headlight on my 2011 Dodge Durango. a new one is $900! Bought an aftermarket regular headlight and my plan was to change the plug on the wiring harness and plug it in to my new light, but there is not 12 volts in the wires leading to the light. can anyone help me with this? ( the high beam,turn signal, and parking light work fine)
Old Nov 13, 2017 | 09:21 PM
Look on AM-Autoparts.com, and see if you can find a replacement headlight for a more reasonable price......
Old Nov 13, 2017 | 10:31 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Yeah just get a used one or aftermarket. That's the stupid Mopar price.
Don't change the car. It's not wired the same at all. You probably just need the shell without ballast, module or wires. You can use your old ones. Just make sure the seals are tight or you'll get water intrusion.
