3rd Gen Durango 2011+ models
Dim HID head lamp
Old Nov 25, 2017 | 12:29 PM
53garyks53's Avatar
53garyks53
Red face Dim HID head lamp
I have a 2011 Durango citadel with factory HID head lamps the passenger side ligt is very dim while the drivers side works fine I don't know if the bulb is burning out or if the baiiast is bad can anybody give me some input? the bulb is very pricey
Old Nov 27, 2017 | 08:00 AM
SHO Rod's Avatar
SHO Rod
Sounds like a bulb issue. If the ballast were the issue I wouldn't expect you to get any light.
If you want to be certain though before buying the expensive bulb, you can swap bulbs from left to right to ensure the dimness follows the bulb.
-Rod
Old Nov 27, 2017 | 09:54 AM
53garyks53's Avatar
53garyks53
Wink Hid light
Thanks for the input switching the drivers side bulb to the passenger side is a good idea its a lot harder to remove things on the driver side to get to the bulb I will buy a bulb and hope that this will fix the issue.
