3rd Gen Durango 2011+ models
Reliability
Old Mar 19, 2019 | 08:18 PM
primem's Avatar
primem
Originally Posted by GDM
rear main bearing replaced under warranty. I have towed a large boat without issues as well.
….why you need a hemi for towing...buy more towing capacity than you need.
Old Mar 27, 2019 | 04:35 PM
vipergg's Avatar
vipergg
Originally Posted by zaktrafton
The TIPM can cause other issues like no power windows, locks, wipers. I had mine rebuilt good as new. (2013)
Be careful with 4000-5000 pounds of trailer behind a durango. Ive seen more than a few suv/trailer combos where the tail wagged the dog right of the side of the road.
Should be fine with a Durango which is larger than I have now and it's stable as a rock behind the Ascender which is shorter in length than a durango .
How much maintenance is there on the 4WD version just out of curiosity ? How much is said maintenance on the 4WD ? Right now Im planning on RWD even here in upstate NY . I have survived the last 10 winters in my RWD Ascender without much issue . To me it just seems like another potential break fix issue plus the added weight you lose 1 mpg .
Old Mar 27, 2019 | 08:45 PM
primem's Avatar
primem
and you lose 300 pounds of tow capacity. AWD probably has a reduced tow capacity vs part time 4wd and 2wd systems.
if your ok in the winter.....only problem with 2wd is when you try to sell it.
Old Mar 29, 2019 | 03:19 PM
vipergg's Avatar
vipergg
Not worried about that , I drive it into the ground .
