3rd Gen Durango 2011+ models
defrost: mirrors and rear are not working
Old Jan 29, 2020 | 05:25 PM
J B's Avatar
J B
Default defrost: mirrors and rear are not working
both side mirrors and rear defrost are not working. 30amp fuse is ok. Anyone have any ideas?
2015 Dodge Durango Limited 6 cyl
Old Jan 29, 2020 | 11:43 PM
primem's Avatar
primem
what model year?
Old Jan 30, 2020 | 09:28 AM
J B's Avatar
J B
ah sorry. 2015 dodge durango.
Old Jan 30, 2020 | 01:57 PM
SHO Rod's Avatar
SHO Rod
When you press the rear defrost button to turn them on does the indicator light come on and stay on? And when you say the side mirrors don't work, are you referring to the side mirror heat/defrost or the position adjustment as well?
-Rod
Old Jan 30, 2020 | 04:41 PM
DodgeCares's Avatar
DodgeCares
Hi J B, We certainly understand why this may be concerning. If you are not able to remedy this concern with the advice provided here, I kindly recommend connecting with your local Dodge dealer. If you are in need of any assistance with that process, our team is available via private message.
Rob
DodgeCares
Old Jan 30, 2020 | 04:42 PM
J B's Avatar
J B
indicator light comes on and stays on. side mirrors and rear defrost are not working. checked fuse, it is good.
Old Jan 30, 2020 | 11:10 PM
SHO Rod's Avatar
SHO Rod
See if you're getting power to both sides of the fuse (fuse 36, 30A) when the rear defrost is turned on. There is a rear defrost relay that should provide power to the fuse. If that relay is bad or not making a good connection, the rear defrost will not get power even if Fuse 36 is good. This, however, would not explain why the heated mirrors don't work, but one step at a time.
The passenger heated mirror is controlled via the Passenger Door Module which is controlled via the CAN bus. Similar story for the driver's side heated mirror, controlled via the Driver's Door Module and CAN bus. There are separate fuses for each door module, but if those fuses were bad, a lot more with the mirrors and doors would fail to work than just the heater.
-Rod
Old Jan 31, 2020 | 03:02 AM
primem's Avatar
primem
have the battery tested and the battery state of health parameter checked with the scan tool. if you have stop/start that has 2 batteries...isolate them and test them individually.
your vehicle has an intelligent battery sensor. If it detects the battery state of health is low...the computer will start load shedding. the defroster is a high electrical load item but its not vital to vehicle operation. the system decides its more important to be able to start and drive the car vs risking a no crank so it disables high load items.
if you replace the battery without clearing the old battery data...it will take 2 days for the ibs to learn the new state of health. ie. it may not work for 2 days after replacing a bad battery..
