3rd Gen Durango 2011+ models
Turn Over / No Start
Old Mar 30, 2020 | 06:41 PM
Chigger's Avatar
Chigger
Default Turn Over / No Start
Hey guys,
I have a 2015 Dodge Durango R/T. 5th time towed into the dealer for a turn over/no start. Battery replaced, fuel pump replaced, some other computer board replaced. Anyone have a link to a TSB on this issue? Hasn't gone to recall yet. There is a TSB (fuel pump relay fuse) for 1st and 2nd generation but nothing I can find for the 2015. Dealer claims they have no idea what the issue is.
Old Mar 31, 2020 | 08:15 AM
SHO Rod's Avatar
SHO Rod
Based on what's been replaced it would seem the dealer thinks there's no fuel, but have they actually confirmed that? Have they checked to see if there's voltage getting to the fuel pump? This doesn't sound like it would be too difficult for the dealer, with access to the factory wiring diagrams and field service engineers, to properly diagnose. Is there another dealership in your area? Or, if this is not under warranty, you might be better off finding an independent shop that specialized in automotive electrical repair if the dealer has confirmed the fuel pump is not getting power.
-Rod
Old Mar 31, 2020 | 03:49 PM
DodgeCares's Avatar
DodgeCares
Originally Posted by Chigger
Hey guys,
Sorry to hear this, Chigger. I would like to help you get this concerns addressed with the help of your dealer by escalating a case for you. Please send us a private message at your earliest convenience.
Lydia
DodgeCares
Old Apr 1, 2020 | 03:01 PM
DDCREW's Avatar
DDCREW
Hey guys,
There is a current recall for fuel pump relay for 3rd gen Durangos, but is for years 2011-2013; no replacement parts available yet. See link below.
https://www.carfax.com/blog/car-reca...uel-pump-issue
Old Apr 4, 2020 | 12:07 PM
Chigger's Avatar
Chigger
DDCREW,
I have sent the service writer and manger several of these type of complaints I found online and they seem clueless. I just got the Durango back after they replaced driver and passenger side fuel pumps for the second time and its dead again. I copied this link and sent it to them.
Thank you!
Old Apr 4, 2020 | 12:15 PM
Chigger's Avatar
Chigger
SHO Rod,
I'm not sure what the dealer is checking, I just know what they claimed to have replaced. I have told them about the other generation Durango's with the same issues (crank-no start), but they seems clueless. Just got it back after they replaced fuel pumps on both tanks. Well it lasted a day and its dead again. I found another possible issue on another site and it said it could be a "failed anti-drainback valve and a faulty TPS triggering limp mode home" or "faulty TIPM fuel pump relay". I mailed my demand letter in yesterday to Dodge for Lemon Law procedures. ???
Old Apr 7, 2020 | 12:10 PM
Chigger's Avatar
Chigger
Lydia (Dodge Cares), I sent you a private message and haven't got a response back yet...
Old Apr 7, 2020 | 04:20 PM
DodgeCares's Avatar
DodgeCares
Sorry about the wait, Chigger. I have responded to your PM. We can continue discussing your concerns there.
Lydia
DodgeCares
Old Apr 8, 2020 | 02:00 AM
master tech's Avatar
master tech
Site Moderator & Tech
Did the vehicle have the update fuel pump relay installed on the cross bar behind the right front headlamp assy. That new relay will be spline into the PDC/IPC, you could have a bad fuel pump relay or a bad PDC/ IPC that is shorting out. Take the relay out and twist the blades a little, not must and plug it back in.
Old Apr 9, 2020 | 04:40 PM
Chigger's Avatar
Chigger
Thanks Master Tech! I'll pass on the info to my service manager. Durango is still in the shop.
