3rd Gen Durango 2011+ models
Excessive Cranking 2021-2025 Dodge Durango
Old Nov 13, 2025 | 01:57 AM
Tom-AMS99's Avatar
Tom-AMS99
Default Excessive Cranking 2021-2025 Dodge Durango
Just sharing recently rec'd TSB:
Technical Service Bulletin
2021-2025 Dodge Durango built from Feb. 1, 2021, thru Nov. 24, 2024, with 3.6L V6 VVT engine.
Excessive cranking time.
The most likely cause is the fuel pressure regulation.
Perform a fuel pressure and fuel system leak-down test.
If not within spec, replace the fuel pump module with P/N 68535771AB.
pic for attention (AirRam Dodge 4.7L heads to Ford/Sullivan hi-rise intake manifold adapters from automotivemachine.com)
