View Poll Results: What gear ratio ya runnin?
3.21
1
0.38%
3.55
57
21.67%
3.73
32
12.17%
3.92
121
46.01%
4.10
20
7.60%
4.56
26
9.89%
4.88
4
1.52%
Other(post in reply)
2
0.76%
Voters: 263. You may not vote on this poll
Gears
Old Mar 15, 2010 | 08:26 PM
  #31
Plainbroke's Avatar
Plainbroke
Does anyone have a crossover for what years interchange the whole rearend..
My 2002 I want to find 3.92s for it but everything I find is 06 or newer..
Old Mar 15, 2010 | 11:04 PM
  #32
Xanlamin's Avatar
Xanlamin
My 2003 2500 has 3.92's, this is on a 1-ton 6.5x8 axle (AAM 11.5)
Old Mar 16, 2010 | 07:18 PM
  #33
chambers's Avatar
chambers
02-08 are the same as far as I know.
Old Aug 30, 2010 | 10:47 PM
  #34
rattlers12's Avatar
rattlers12
hi, im new to this forum and completey new to dodges. i just got a 2002 dodge 1500. it has the 5.9 in it. it is lifted 9 in with 37s. as far as i know it still had the stock gears i it. i dont do much highway driving. mainly just around town. what gears would yall recommend for it? any suggestions apprecated
Old Sep 25, 2010 | 10:58 AM
  #35
bartvandenberg's Avatar
bartvandenberg
check out your glove box... should be a sticker in it telling you what gears you have in your truck.
i have 3.55's in my 05, and looking to upgrade to 4.56. But.. since im very mechanically retarded, anyone know what i should be looking for? or a good place to get gears (possibly from canada?)
I see some richmond gear stuff, but so many options, i have no idea which I would need to get. Some are 200, some kits are 900.... so.. WTH?
anyone shed some light? Id really appreciate it.
Old Sep 25, 2010 | 12:23 PM
  #36
chambers's Avatar
chambers
2wd or 4wd and are you trying to put a limited slip in the rear?
Old Sep 25, 2010 | 12:53 PM
  #37
bartvandenberg
I've got a 2wd
and no... i dont care to put a limited slip in. Just replace what I have stock with 4.56 gears.
I have a posi rear end right? (sorry.. like i said... mechanically retarded)
Old Sep 25, 2010 | 06:53 PM
  #38
chambers's Avatar
chambers
I've got a 2wd
If you have 3.55's then it's very unlikely you have a posi/lsd b/c only 3.92's came w/ the anti slip rear. You need to get the gears and a master install kit, I suggest a LSD to aid traction in bad weather. I had some problems w/ a couple motive sets so I don't recommend them. I have yukon gears in my truck and even if you got motive gears it's unlikely you'd have a problem since that is what most guys here have. The gears are pretty much $200 and up, the master install kit is about $100, and labor will run you at least $300. Post a thread in the 3G section to see if anyone knows a good gear shop in your area b/c this isn't a job any mechanic can do. It's a good idea to get the parts from the shop you get the install at so they can't blame any problems on you or the parts, but it may cost you a little more for the parts. Good luck.
Old Sep 25, 2010 | 07:40 PM
  #39
bartvandenberg
If i brake torque (sp?), both wheels spin, and going around corners, my one wheel spins just as fast as my other one, making it always slip a bit. Isnt that posi?
maybe im dumber than I thought
Old Sep 25, 2010 | 10:02 PM
  #40
SLT8's Avatar
SLT8
Monday - 4.10's coming out 4.88's going in.
