View Poll Results: What gear ratio ya runnin?
3.21
1
0.38%
3.55
57
21.67%
3.73
32
12.17%
3.92
121
46.01%
4.10
20
7.60%
4.56
26
9.89%
4.88
4
1.52%
Other(post in reply)
2
0.76%
Voters: 263. You may not vote on this poll
Gears
Old Oct 1, 2010 | 04:58 PM
  #51
chambers's Avatar
chambers
Originally Posted by DodgEclectic
so what is the next size up? and what am I looking at spending?
Is your truck an auto or stick b/c the o/d ratio will effect the rpm you're running at highway speed? If it's an auto then 4.56's are as far as I'd go w/ 33's unless you almost never take it on the highway. Cost can vary, minimum for gears $180, master install kit $100, labor $3-400. The key is to make sure the shop knows what they're doing and have done a lot of dodge 9.25 rear ends.
Old Oct 1, 2010 | 08:15 PM
  #52
RedTruck-VA's Avatar
RedTruck-VA
Originally Posted by kay9
It is very responsive from idle and once you get past the high rpms, is very nice on the highway. I am still leery of getting on it now with the replacement drive shaft. That was a scary incident and could of been much worse. Still jolted about it all.
Anyway she is back at home and now i can look under and see what needs to be replaced, which right now is full piping and muffler from the ORY back.
The 4.10's worked for my old set up but i need to recover as much low end as i can in addition to getting into the power band fast as possible. The shift recovery from the 3400 stall will keep it there.
I had one really bad drive shaft incident that stayed with me for a long while which reminds me, I still need to install a safety hoop. With your new setup sounds like you are building a 7k rpm motor. How are you going to hook that beast up? Tub it?
Old Oct 1, 2010 | 09:28 PM
  #53
SLT8's Avatar
SLT8
Man it sure is a wake-a-upper thats for sure.
Gonna invest in moes driveshaft loop very soon. The 88's should give me a lot of play in trying out different tire sizes so i can work in still trapping at the top of 3rd. Right now for the street i may just run 18" in the rear on Nitto DR's. Keep my current 17's on the front. Once the 3400 stall is in then it is time to get the tuning done then tweak the suspension and then weight transfer. I would love to run 20" rims one day.
I wont be upgrading my heads for a LONG time.
I have also thought of just keeping it a street truck only and not worry about the track. Just drive it and enjoy it.
Old Oct 2, 2010 | 04:57 AM
  #54
RedTruck-VA
I hope you keep it a street truck. IMO, a racer is just a racer. But a modified street ride is so much more classy. After all a dedicated racer is just a vehicle that's trying to be faster than a street car by removing all the creature comfort.
Nothing's kooler than a street racer rolling into the parking lot showing it's stuff.
Old Oct 4, 2010 | 04:07 PM
  #55
DodgEclectic's Avatar
DodgEclectic
4.56's.. 4.88's if 2wd.. Just make sure your driveshaft is inline LOL.
Well i have a 4x4. i think what i am going to do is save up and go with the 4.56s. thanks!
Old Oct 4, 2010 | 04:11 PM
  #56
DodgEclectic
my truck is an auto and its a 4x4. i go on the freeway rarely... but when i do they are longer drives...i mostly drive around the suburbs of folsom. and a few more people said that i should with the 4.56s... and thanks for the pricing too... very awesome and great info.
Old Oct 4, 2010 | 06:34 PM
  #57
SLT8's Avatar
SLT8
Awesome. Should be a VERY noticable difference.
Old Oct 5, 2010 | 06:28 PM
  #58
chambers's Avatar
chambers
Yea just keep in mind for the 4x4 it will be 2 installs, 2 sets of gears, and 2 master install kits.
Old Nov 27, 2010 | 05:19 PM
  #59
2006DRamHemi's Avatar
2006DRamHemi
does anyone know if they make 4.56 gears for a corporate 14 bolt rear for my 2006 Dodge Ram 2500?
Old Nov 27, 2010 | 06:50 PM
  #60
SilverHemiDan's Avatar
SilverHemiDan
yes,I had 4.56's put it(best mod to date) I'm running 37" tires
do you have gas or diesel engine?
All diesels 04+ have the AAM 11.5" axle.
All 3500's have the AAM 11.5" axle regardles of engine.
All 2500 hemi's have the AAM 10.5" axle.
