Superchips Questions and Updates
I don't plan on givin up on you guys but hopefully you don't HIV up on us 03 guys! We love our superchips just as much as anyone else. thanks
WOT TM pictured below.
This is one of the WOT shifts set at 10% TM. Slight calculation error in this firmware. Engineer is aware and they'll make the necessary adjustments.
PT TM MGT will allow adjustment of four different RPM ranges. 1-4 shifts. (not shown)
PT SHIFT SCHEDULE you saw in this previous post: You can user adjust upshifts and keep downshifts at SC value or vice versa or use stock values as well.
Surprise added bonus in this firmware. When I can verify it will be included in production, I'll let you guys know.
Sil
Sil
Or is the 4.7 engines going to take a whole new set of programs and testing from scratch?
DK
Just curious...How hard will it be to migrate to the 4.7 engines? I'm assuming once they get the 5.7 engines nailed down there won't be too much difference in the programming correct?
DK
DK
Having said that, since they undertstand what they're doing and learning things during this process, other applications could go quicker. Emphasis on 'could'.
Sil
DK
DK
For instance, my '07 4.7 has a "unique" code that took months for SC to figure it out just to get the 3815 to work with it (hopefully this is not the case again).
