Superchips Questions and Updates
Old Sep 14, 2009 | 11:33 PM
  #1201
ThunderedRod's Avatar
ThunderedRod
Originally Posted by Off_Road_Teacher
Sounds awesome, I can't wait to get a chance to try these new features!
I hear that! The best part is that the chip is already paid off!!
Old Sep 15, 2009 | 10:16 AM
  #1202
SilsHemi's Avatar
SilsHemi
Thumbs up
Folks,
Just an FYI. The new Superchips forum is up and running.
If you need support or have a question, please don't hesitate to use the forum.
Here's the link: http://www.superchips.com/forum/
Sil
Old Sep 15, 2009 | 05:39 PM
  #1203
Mega-Hemi's Avatar
Mega-Hemi
I got another question.. Since I have an '02 with the 5.9 and 46RE, the new trans programs will do nothing for me, right? With that being said, is there any other benefit to buying the 3865 over the 3715?? Or will the 3715 do all I can with my older truck anyway? I plan to purchase one soon but don't want to over spend for new technology that's not going to benefit me anyway. Thanks.
P.S. I was also told that I could get rid of my "Death Flash" with a superchips tuner. True or False??
Old Sep 15, 2009 | 10:16 PM
  #1204
MDSBigPaPa's Avatar
MDSBigPaPa
Default Latest testing on db 009 - Beta V2
Flashpaq 3865 Beta V1.18.04 Gas Truck db 009
New Beta release yesterday so here's a look at my latest testing.
These are the settings I have:
Rev Limiter: 6250
Speed Limiter: 140
WOT 1-2: 5700
WOT 2-3: 5750.
My Truck: 2007 RAM 2500HD MegaCab SLT 4x4
With the release of db 009, I have correct (for the most part) calibration values for MPH. I’ve included the table entries below for your information and as you look through the values below, you’ll notice what may be anomalies: I’ve highlighted those values.
Errors were returned on DB 009 for ODrive Off Shift Sch.: That is I cannot change the values due to the following errors:
• Shift 4 dn – “Select User shift schedule to modify”
• Shift 3 dn – “Select User shift schedule to modify”
• Shift 2p dn – “Select User shift schedule to modify”
“User” was selected for all shift points.
As for the “tuner failure”, I believe it may be related to a hardware failure with the down arrow. It has been a little sticky, many times I’ll get a second beep but only one line is processed. It has happened two more times:
• After doing some data logging, I started the tuning process to collect MPH tables and load the 009 db. I selected tune and when I pressed down arrow to get to Advanced it failed.
• The second time it happened I was using down arrow to Save and Exit the Low Shift Sch. values so I could change ODrive Off Shift Sch. – this was common with the initial failure but, cannot say it is truly related because it happened one step prior to the first failure.
Questions:
• With Speed Limiter set to 140 MPH and the Range High Limit greater than Speed Limiter, what value is superseded: Range High Limit or Speed Limiter? For example: Shift Schedule, “Shift 4 up” has an upper limit of 209.1 MPH yet Speed Limiter is set to 140 MPH. Should it display something like:
If Range High Limit > Speed Limiter then Range High Limit = Speed Limiter
It is somewhat confusing the way it is now.
• Is Speed Limiter used in any of the table calculations?
• Is it possible to set a Set Point value greater than Speed Limiter? Should it be?
Below are the default values for the db 009 calibration values. NOTE: Your values may vary based on your truck's calibration tables.
Columns 1 and 2 in the tables below are the values on the display screen. Columns 3, 4 and 5 are from the modification screen.
• Shift Schedule
• % Shift 1 up mph
% MPH Set Point Range from Range to
0.000 12.34 12.34 3.293 18.93
11.76 13.99 13.99 3.293 23.05
18.03 15.64 15.64 3.293 25.52
23.92 20.58 20.58 3.293 35.40
29.80 29.63 29.63 3.293 47.75
44.70 42.81 42.81 3.293 72.45
59.60 48.57 48.57 3.293 84.80
100.0 48.57 48.57 3.293 84.80
• % Shift 2 up mph
0.000 18.93 18.93 12.34 27.99
7.843 21.40 21.40 13.99 32.10
15.68 24.69 24.69 15.64 37.87
20.00 27.16 27.16 18.11 46.92
29.80 47.75 47.75 29.63 65.86
47.45 77.39 77.39 44.45 93.63
59.60 84.80 84.80 48.57 93.63
100.0 84.80 84.80 48.57 93.63
• % Shift 2p up mph
0.000 27.99 27.99 19.75 30.46
14.90 36.22 36.22 24.69 41.98
25.88 59.27 59.27 40.34 64.21
44.70 93.03 93.03 73.27 113.60
100.0 93.03 93.03 84.80 113.60
• % Shift 3 up mph
0.000 30.46 30.46 27.99 51.04
8.235 31.28 31.28 32.93 51.04
13.33 38.69 38.69 35.40 61.74
24.70 65.86 65.86 57.63 144.9
34.90 94.67 94.67 75.74 144.9
34.90 127.6 127.6 75.74 144.9
100.0 127.6 127.6 93.03 144.9
Note 1: Set Point 31.28 is outside of default range
Note 2: 144.9 is > Speed Limiter
• % Shift 4 up mph
0.000 51.04 51.04 31.28 209.1
8.235 51.04 51.04 31.28 209.1
20.00 77.39 77.39 55.16 209.1
22.35 97.97 97.97 60.92 209.1
22.35 144.9 144.9 60.92 209.1
100.0 144.9 144.9 127.6 209.1
Note 1: 209.1 is > Speed Limiter
• % Shift 5 dn mph
0.000 47.75 47.75 26.34 209.1
21.56 47.75 47.75 26.34 209.1
29.80 64.21 64.21 38.69 209.1
37.25 88.91 88.91 46.10 209.1
40.78 139.1 139.1 56.80 209.1
100.0 139.1 139.1 105.3 209.1
• % Shift 4 dn mph
0.000 26.34 26.34 11.52 47.75
19.21 26.34 26.34 11.52 47.75
37.25 46.10 46.10 29.63 88.91
44.70 67.51 67.51 36.22 139.1
48.23 81.50 81.50 39.51 139.1
54.90 81.50 81.50 57.63 139.1
54.90 105.3 105.3 57.63 139.1
100.0 105.3 105.3 81.50 139.1
• % Shift 3 dn mph
0.000 11.52 11.52 11.52 26.34
31.37 11.52 11.52 11.52 39.51
31.37 23.87 23.87 11.52 39.51
52.15 42.81 42.81 42.81 81.50
54.51 55.16 55.16 55.16 81.50
59.60 81.50 81.50 81.50 101.2
100.0 81.50 81.50 81.50 101.2
• % Shift 2p dn mph
0.000 11.52 11.52 11.52 11.52
31.37 11.52 11.52 11.52 11.52
31.37 23.87 23.87 11.52 11.52
52.15 42.81 42.81 11.52 42.81
54.51 55.16 55.16 11.52 54.33
100.0 55.16 55.16 36.22 81.50
Note: Set point outside allowable range
• % Shift 2 dn mph
0.000 11.52 11.52 3.293 11.52
59.60 11.52 11.52 3.293 54.33
59.60 36.22 36.22 3.293 54.33
100.0 36.22 36.22 3.293 54.33
Menu selection:
• Low Shift Schedule
• % Shift 1 up mph
0.000 10.70 10.70 3.293 18.11
9.020 12.34 12.34 3.293 19.75
18.43 13.99 13.99 3.293 27.16
40.78 30.46 30.46 3.293 62.57
44.70 36.22 36.22 3.293 69.15
100.0 36.22 36.22 3.293 69.15
• % Shift 2 up mph
0.000 18.11 18.11 11.52 32.93
7.451 19.75 19.75 12.34 32.75
14.90 22.22 22.22 13.99 41.16
25.88 38.67 38.67 19.75 52.69
36.47 56.80 56.80 27.99 62.57
44.70 69.15 69.15 36.22 71.62
100.0 69.15 69.15 36.22 88.09
• % Shift 2p up mph
0.000 32.93 32.93 18.11 46.10
5.882 32.93 32.93 19.75 46.10
25.88 52.69 52.69 38.69 88.91
44.70 71.62 71.62 69.15 120.2
44.70 88.09 88.09 69.15 120.2
100.0 88.09 88.09 69.15 120.2
• % Shift 3 up mph
0.000 46.10 46.10 32.93 205.8
5.882 46.10 46.10 32.93 205.8
18.43 64.21 64.21 46.10 205.8
33.33 114.4 114.4 60.92 205.8
33.33 121.0 121.0 60.92 205.8
100.0 121.0 121.0 88.09 205.8
Note: 205.8 is > Speed Limiter
• % Shift 4 up mph
0.000 205.8 205.8 205.8 209.1
100.0 205.8 205.8 205.8 209.1
Note: all values > Speed Limiter
• % Shift 5 dn mph
0.000 171.2 171.2 26.34 209.1
100.0 171.2 171.2 105.3 209.1
Note: values > Speed Limiter
• % Shift 4 dn mph
0.000 25.52 25.52 4.940 171.2
22.35 49.39 49.39 4.940 171.2
40.00 82.33 82.33 32.10 171.2
52.15 105.3 105.3 52.69 171.2
100.0 105.3 105.3 59.27 171.2
• % Shift 3 dn mph
0.000 4.940 4.940 4.940 25.52
35.68 4.940 4.940 4.940 79.09
35.68 23.87 23.87 4.940 79.09
52.15 52.69 52.69 52.69 105.3
59.60 59.27 59.27 59.27 105.3
100.0 59.27 59.27 59.27 105.3
• % Shift 2p dn mph
0.000 4.940 4.940 4.940 4.940
35.68 4.940 4.940 4.940 4.940
35.68 23.87 23.87 4.940 4.940
52.15 52.69 52.69 4.940 25.69
59.60 59.27 59.27 25.52 59.27
100.0 59.27 59.27 25.52 59.27
Note: Set point is outside allowable range
• % Shift 2 dn mph
0.000 4.940 4.940 3.293 4.940
52.15 4.940 4.940 3.293 52.69
55.68 25.52 25.52 3.293 55.16
100.0 25.52 25.52 3.293 59.27
Menu selection:
• ODrive Off Shift Schedule
• % Shift 1 up mph
• % Shift 2 up mph
0.000 24.69 24.69 12.34 36.22
5.882 25.52 25.52 13.17 36.22
22.35 47.75 47.75 19.75 58.45
44.70 85.62 85.62 42.81 97.97
59.60 85.62 85.62 48.57 97.97
59.60 88.09 88.09 48.57 97.97
100.0 88.09 88.09 48.57 97.97
• % Shift 2p up mph
0.000 36.22 36.22 154.7 53.51
6.667 36.22 36.22 154.7 54.33
25.88 64.21 64.21 154.7 121.0
44.70 97.97 97.97 154.7 127.6
100.0 97.97 97.97 154.7 127.6
Note 1: Value is > Speed Limiter
Note 2: Set Point is outside allowable range
• % Shift 3 up mph
0.000 53.51 53.51 36.22 147.3
8.235 55.16 55.16 38.69 147.3
16.47 75.74 75.74 51.04 147.3
22.35 115.2 115.2 59.27 147.3
29.80 127.6 127.6 71.62 147.3
100.0 127.6 127.6 97.97 147.3
• % Shift 4 dn mph
• % Shift 3 dn mph
• % Shift 2p dn mph
• % Shift 2 dn mph
Menu selection:
 WOT Trq. Mgt
• Gear WOT TrqMgt. %
Gear % Set Point Range from Range to
_1_st 86.00 86.00 0.000 100.0
_2_nd 80.00 80.00 0.000 100.0
_3_rd 80.00 80.00 0.000 100.0
_4_th 80.00 80.00 0.000 100.0
• RPM Part 1 up %
RPM % Set Point Range from Range to
1728 64.00 64.00 0.000 100.0
2400 52.00 52.00 0.000 100.0
3744 59.20 59.20 0.000 100.0
5408 86.00 86.00 0.000 100.0
• RPM Part 2 up %
1504 62.00 62.00 0.000 100.0
2816 52.00 52.00 0.000 100.0
4096 47.00 47.00 0.000 100.0
5408 80.00 80.00 0.000 100.0
• RPM Part 3 up %
1504 84.80 84.80 0.000 100.0
2816 68.00 68.00 0.000 100.0
4096 58.00 58.00 0.000 100.0
• RPM Part 4 up %
1504 76.00 76.00 0.000 100.0
2816 70.00 70.00 0.000 100.0
4096 64.00 64.00 0.000 100.0
More to come...
Old Sep 16, 2009 | 07:11 AM
  #1205
pavester's Avatar
pavester
so am i kinda in the dark with a 3815? all im really looking for is eliminating tq management and ability to program/and stiffen my shift points so i dont have to drive in tow/haul anymore lol
Old Sep 16, 2009 | 09:23 AM
  #1206
MDSBigPaPa's Avatar
MDSBigPaPa
Yes. The 3815 does not have the storage capabilities for the tranny options. The 3865 is the next generation flashpaq.
Old Sep 16, 2009 | 09:29 AM
  #1207
Off_Road_Teacher's Avatar
Off_Road_Teacher
In the TM tables that you posted it reads the TM set point to be 86% followed by 80%, 80% and 80%. Does that mean that it is programmed as an 80% reduction in TM or that there is still 80% of TM remaining?
Old Sep 16, 2009 | 10:50 AM
  #1208
MDSBigPaPa's Avatar
MDSBigPaPa
Good question! What you're seeing is % of Stock TM. That is, Stock TM is 100% and the set point is a percentage of Stock. So 80% is a 20% reduction from Stock.
Old Sep 16, 2009 | 12:47 PM
  #1209
Off_Road_Teacher
Is a 20% reduction how much the standard SC performance tune reduces TM?
Old Sep 16, 2009 | 02:19 PM
  #1210
MDSBigPaPa's Avatar
MDSBigPaPa
I believe that is proprietary information so I don't know. The numbers above are simply the "User" defaults and adjustable.
I've set TM for all shift points to 10% and the shift performance has changed for the better but, I've only had it set one day so it's too early to get specific.
