Superchips Questions and Updates
Old Dec 31, 2010 | 09:08 PM
  #2761
MDSBigPaPa's Avatar
MDSBigPaPa
Originally Posted by bjv311
I've been lurking the forums for a while but rarely post. I was going to see if anyone else had this issue with superchips.
When i have it WOT and it shifts from 2nd-3rd it then downshifts again and then goes up. I'm trying to figure out what is going on and how to fix it.
i have 1st-2nd WOT shift set at 5450 and 2nd-3rd @ 5450. This is on the performance 91 tune with rev limiter @ 6200, and Torque management @ 8%. Also have it set to let superchips do the up/dn shifting. Any tips on what to do would be much appreciated. I have a video link if anyone is interested.
Thanks
I set my WOT 1-2 to 5850 and WOT 2-3 to 5800.
Try adjusting your WOT values upwards until it goes away. What you may be running up against is the upper TP% range on 2Dn is a higher MPH than your WOT setting: For example, 2Dn 59.6% is 87MPH but the MPH reached at 5450 is only 81-82MPH (by your video) so it down shifts because because it's lower than the 87MPH setting at 59.6%.
Old Dec 31, 2010 | 10:49 PM
  #2762
bjv311's Avatar
bjv311
Talking
now that i think about it, that makes perfect sense. I will adjust those settings to what you posted and leave the up/dn shift setting from superchips. Thanks!
After that gets worked out, I will try messing with the TP%/mph and doing my own custom settings (altered from matt/eric shift schedule). Does anyone have their own there willing to post just to compare. I just got the flashpaq on saturday, and after buying the trans upgrade. I think i have found a 2nd wife =/
Old Dec 31, 2010 | 11:38 PM
  #2763
AZZO540's Avatar
AZZO540
the trans tune is good.
Old Jan 1, 2011 | 05:59 PM
  #2764
MDSBigPaPa's Avatar
MDSBigPaPa
You're Welcome! Let us know how you make out. Check other schedules on www.mcfail.net/superchips you'll find a lot of possibilities. Be sure to build(use an existing schedule) Excel spreadsheet and modify it for your use.
Old Jan 1, 2011 | 06:00 PM
  #2765
Dude2006's Avatar
Dude2006
Default "Chip" for a 2006 2500
Hey people;
Just wanted some info in regards to these aftermarket chips. I just installed a GForce chip with the two wire plug and go. Says that it takes about 100 miles for my truck to "learn" the chip. Ran the truck for about ten minutes and my check engine light came on. Is this normal? Or should I unplug the chip and chunk it?
Thanks;
Chris
Old Jan 1, 2011 | 06:12 PM
  #2766
HammerZ71's Avatar
HammerZ71
Originally Posted by Dude2006
Hey people;
Thanks;
Chris
Yank it out, it's a scam. Do a Google search or you can start here:
http://www.performancechips.com/g-fo...ip-reviews.php
You'll honestly gain more power from just a cooler thermostat.
I thought I read where they got shut down or ebay refused to let them sell through there a while ago. I see they still have a website though...
Old Jan 7, 2011 | 08:47 PM
  #2767
06 Ram5.7's Avatar
06 Ram5.7
I know before they updated the Superchips website and got rid of it, you were able to go to flashpaq.com, pick your programmer and look up all the database and software updates, and what each update fixed/added. I tried looking for it, but I couldn’t find it anywhere on Superchips website of the Superchips forum. Does anyone know if they still have the list somewhere, or did Superchips stop releasing update information?
Old Jan 8, 2011 | 02:28 PM
  #2768
MDSBigPaPa's Avatar
MDSBigPaPa
They quit when they moved to their new servers. A lot of folks have asked for its return and, they say it's coming back but, "when" is the operative word.
Old Jan 8, 2011 | 11:32 PM
  #2769
BLACKRAM2u's Avatar
BLACKRAM2u
Default usb port time out
Hey guys once again with some questions here. I just got yesterday my 3865 sc and installed the 93 tune. And then i wanted to adjust the shift,torque etc. and it said select user but i couldn't. so i went to my pc and tryed to upgrade or try to get it to user and started analyzing programer and then sc said usb port time out. and doesn't do nothing else for hours.
Old Jan 9, 2011 | 09:31 AM
  #2770
pitbull24's Avatar
pitbull24
BLACKRAM2u,
You have to purchase($40) the Trans Tuning package, and download it to your 3865. When you get a "time out" error it's time to start over. I've had similar issues when updating my 3865; not sure if it's SC server/website, or my internet service. No need to wait for hours; if you get the time out error unplug and try to connect again.
