Superchips Questions and Updates
I have noticed since I reloaded the 87 tune to my truck, that I have seen the decel fuel cut off sooner than expected. For example, I'll be going about 65 and start down a hill...let off the accelerator and the engine speed will drop a bit, fuel flow drops about in half, and then I see fuel flow stop for about a second, then it resumes and the fuel flow comes back up. Did SC happen to change any parameters for the decel fuel cutoff in recent updates?
Hi All
My Superchips flashpaq is here, well i have to collect it tomorrow morning from the depot, bloody £75 import duty what a rip off, still at least i can play with it tomorrow. So get ready for the barrage of questions
Well, That seemed relatively easy, plugged it in downloaded software, plugged into OBD11 saved stock file and loaded performance file, WOW what a difference, going to load the towing program next when i take out my 5th wheel then maybe purchase the trans upgrade if i feel the need.
Cheers
Neil
Cheers
Neil
Six of the eight guys bought a Superchips tuner within weeks of trying mine...
Yes, stock is saved into the programmer and the unit becomes vinlocked to the vehicle at that point. Vinlocking helps preserve the stock setting so in the event you need to return to stock you can without issue.
You will definitely see better throttle response TQ and MPG using the different tunes included in the product.
Any further questions feel free to let me know.
Scott
Scott
Cheers
Neil
Cheers
Neil
Worth every dime a million times over....
