Superchips Questions and Updates
Old Sep 23, 2012 | 01:31 PM
  #3421
Chade7320's Avatar
Chade7320
Originally Posted by Dead2Fall
If you buy the cortex it comes with a tranny waranty
It looks like from reading over the warrenty your truck can't have over 100k miles.
Old Sep 23, 2012 | 04:09 PM
  #3422
redram2007's Avatar
redram2007
Default Superchips vivid questions
So i installed my superchips vivid and set it on 91 oct. performance mode. now when i turn the a/c on the blower is making a whistling noise. i looked at the program and it has 3 settings for the fan. when i chose the 91 oct. it set my fan low, med, and high all to the same value. i do not have an e fan just oem clutch fan. any help would be awesome.
Old Sep 24, 2012 | 09:07 AM
  #3423
Scott@Superchips's Avatar
Scott@Superchips
Former Vendor
PM sent
Scott
Originally Posted by looka
Thanks. I wanted to get on the forums so that I could discuss some issues I've had with my new tuner. The flashpaq has reset itself several times when I'm right in the middle of adjusting the settings. So I have to go back and start all over again. It's beyond annoying.
Also, we need to get some more shift schedules because the ones for the 2006 are completely wack. Two of the schedules have mph settings that aren't even available on my new flashpaq.
So yeah, would be nice if I could access the superchips forums to get this worked out. Maybe get a new tuner or something.
Old Sep 24, 2012 | 09:15 AM
  #3424
Scott@Superchips
Former Vendor
The fan setting is for vehicles that have an electric cooling fan for the radiator. Since that's not an option on your vehicle I would leave it as is and move to the next option you want to adjust.
Scott
Old Sep 24, 2012 | 10:39 AM
  #3425
redram2007's Avatar
redram2007
Scott
Awesome thank you. I just used the 91 perf. and it was one of the package values preset in the tune. so your basically saying i should retune and put the fan adj to stock values instead of sc values that is already preset?
Old Sep 24, 2012 | 11:35 AM
  #3426
Scott@Superchips
Former Vendor
Since your vehicle runs a fan clutch the setting you have will not affect anything. You can leave it or if it bothers you retune. it's up to you.
Old Sep 24, 2012 | 01:15 PM
  #3427
redram2007's Avatar
redram2007
Cool i figured it out and thank you for the info
Old Sep 24, 2012 | 01:45 PM
  #3428
Scott@Superchips
Former Vendor
Happy to help my friend!
Old Sep 24, 2012 | 04:25 PM
  #3429
RCW35120's Avatar
RCW35120
Default Which Programmer????
I have an '04 Ram 1500 Hemi Sport 2WD, Cold Air Intake and Air Raid throttle body spacer. Looking to purchase a programmer next. What do you guys recommend????
Old Sep 24, 2012 | 04:31 PM
  #3430
Scott@Superchips
Former Vendor
If you have an android phone running the 2.2 OS or higher I would suggest the VIVID LINQ PN. 138650 or you can go with our most popular and best bang for the buck the Flashpaq PN. 3865.
Both will provide you with best in class performance & drivability while still keeping you 100% emissions legal.
Scott
