Diablo Information and Reviews
Old May 29, 2010 | 11:24 PM
  #651
AF_HEMI's Avatar
AF_HEMI
I get the ABS light that stays on after I reload a tune or reset the pcm, but it goes away as soon as the truck moves. Im not sure why yours would be staying on.
Old May 30, 2010 | 12:26 PM
  #652
weedahoe's Avatar
weedahoe
Hall of Fame Member
You said you have the v04 crom on your DSP. Have you tried updating it to the new v07?
Old May 30, 2010 | 12:36 PM
  #653
RedTruck-VA's Avatar
RedTruck-VA
Weed, I downloaded V07 last night.
I read on the DSP forum that this was a reported problem with DSP DR03 firmware. Suposely DR04 directly addressed this problem and fixed it. My DSP had DR04 firmware installed when this problem came up yesterday. Actually, while loading a tune a few days ago the same thing happened and while backing up (30-40 ft) it went out. Last evening, I installed the original tune back in the truck and updated the firmware to the latest version (v07). This morning I installed the canned 93 tune + wheel hieght. Ran it 1/4 mile, turned it off/on, backed up about 100 feet, and then drove it about 8 miles. I still have the ABS warning light. Oh, lol and tapped on the housing for good luck. I have no codes. The 03 Dodge manual says if the HCU is replaced, it has to be flashed using the DRBII tool. I'm wondering if the DSP screwed up my HCU settings. I just don't know enough about this. But I can clearly say the DSP caused this problem and I am not a happy camper. Any input is appreciated.
Old Jun 9, 2010 | 07:55 PM
  #654
Off_Road_Teacher's Avatar
Off_Road_Teacher
Any update on getting this fixed?
Old Jun 11, 2010 | 09:36 AM
  #655
truckin151's Avatar
truckin151
Anyone know who all is good (and I do mean good) at doing a custom tune with diablo? I thought that HemiFever could write a tune using a DSP....right? or is he strickly SCT???
Old Jun 11, 2010 | 09:41 AM
  #656
glass3222's Avatar
glass3222
HemiFever does do a good tune with the DSP.
I think Stu from inertia and Marty from KRC do as well.
Old Jun 12, 2010 | 05:49 PM
  #657
RedTruck-VA
Truckin,
I think I'll wait and see how it goes for you before jumping in. I figure I'll do a custom tune sooner rather than later as I feel there is a lot of untapped power available with a proper tune.
Good luck.. pls keep us updated..
Old Jun 18, 2010 | 02:16 AM
  #658
Marx's Avatar
Marx
has anyone tried the new DiabloSport Trinity its a turner and a monitor
http://www.diablosport.com/index.php...isplay&pid=151
Old Jun 18, 2010 | 08:01 AM
  #659
weedahoe's Avatar
weedahoe
Hall of Fame Member
Well its not new but yes I have one and yes I absolutely love it. If you ever get one you will not go back to a Predator.
The good things about it is that is will read more PIDs than a Predator and has a slot for an SD card if you want to record to it instead of internal memory. It also needs no additional power cable unlike the Predator and it has a 2.5mm plug so you can add two external devices like a wideband meter (which is why I have an Innovate LC1)
Old Jun 18, 2010 | 08:24 AM
  #660
RedTruck-VA
Weed,
Very nice.
Unfortunately, I have lost confidence in my DSP...
