Diablo Information and Reviews
Old Apr 24, 2011 | 09:52 PM
  #931
minezee's Avatar
minezee
so what did you have to do? just like you, i do not have the options for the upshift and downshift adjustments.
Old Apr 25, 2011 | 02:49 PM
  #932
truckin151's Avatar
truckin151
minezee, there are a couple things you can do.
- Post your issue on the diablo forums, they usually will answer your question in about 24hrs.
In the meant time though,
- Check the CROM that you have loaded, 9r05-9r07 had issues with the transmission settings not loading on the 05's.
- Before you plug the tuner into the truck, turn the key "on" (not starting) and try loading the tune.
- if you have done both of those go into the options menu and check you Calibration ID numbers, should have one for the PCM and one for the TCM.
- If you have one for the TCM it is reading the TCM file
Old Apr 25, 2011 | 05:57 PM
  #933
minezee's Avatar
minezee
truckin, i checked the calibration numbers and there are both PCM and TCM numbers listed. is there something i can do to switch this? also what do you mean by check the CROM?
Old Apr 25, 2011 | 09:54 PM
  #934
lxman1's Avatar
lxman1
Site Moderator
It should say at the top of the main screen after you power it up. crom9r11 is the latest.
Old Apr 26, 2011 | 09:55 AM
  #935
truckin151's Avatar
truckin151
No you want the PCM and TCM numbers listed, that means its reading and writing to both. So your CROM (tune revision) is more than likely the newer version. They release a newer CROM revision every so often to update your tuner. So check it bgut if it says you have a TCM calibration ID you should be fine.
Are you just having trouble finding the screen to modify the transmission shifts?
Old Apr 26, 2011 | 06:10 PM
  #936
minezee's Avatar
minezee
yeah mine says v9r04...so i guess im gonna get some cables to update it to the latest version...will i find the latest update on the diablo site? i assume that the screen to modify the shifts is under quick adjust, or where you select the perf octain upgrades, if its somewhere else let me know...thanks for the help.
Old Apr 26, 2011 | 11:04 PM
  #937
truckin151's Avatar
truckin151
the 9r04 should work out, mine did, but yeah the latest is 9r10 I think.
For the 9r04, here is where you go. (They changed it slightly in the newer versions)
Old Apr 26, 2011 | 11:20 PM
  #938
oefootball_70's Avatar
oefootball_70
SO I have been gone for a long time, Diablo has trans partial shift points now too?
And it does support the 05 4.7 now?
Thanks
Old Apr 26, 2011 | 11:30 PM
  #939
truckin151's Avatar
truckin151
Theyve always done part throttle for certain years with the hemi's, I know they support the 4.7, but not sure what they do as far as part throttle goes
Old Apr 26, 2011 | 11:53 PM
  #940
minezee's Avatar
minezee
oh hell yeah! i just didnt know where to look... how did you determine what changes to make?
