Data Loggers
Old Apr 22, 2010 | 04:11 PM
  #191
truckin151's Avatar
truckin151
Back to the data logging stuff now, my goal at this point is to get it down into the sub 4 sec for 0-60's and I know it is possible with a RCSB too. Just gotta figure out how much my cam will take off with the combination of mods I have. The cam alone will do quite a bit but the other supporting mods should drop it down to the 4.9x I would think
Old Apr 22, 2010 | 04:12 PM
  #192
Off_Road_Teacher's Avatar
Off_Road_Teacher
You mean like 3.xx?????
Old Apr 22, 2010 | 04:33 PM
  #193
RedTruck-VA's Avatar
RedTruck-VA
Well in theory if you are making too much power on launch and spinning hard, moving the cam power band upward would in fact make the truck quicker. This would allow a harder launch and then more power available after hooking up. So designing the cam would entail determining maxiumum lift and then shifting overlap/duration to slide the torque up and/or down to where it is most benefical for our traction abilities. Anyone know who can grind custom cam shafts. This could be fun...
Old Apr 22, 2010 | 04:36 PM
  #194
Off_Road_Teacher
Pretty sure Stu, Marty or Comp will custom grind a cam for you.
Old Apr 22, 2010 | 04:38 PM
  #195
RedTruck-VA
Originally Posted by Off_Road_Teacher
FYI: thread is stuck. If it stays busy I will leave it up here but if it dies off then it will have to come down. So keep the performance talk up guys!
Wow, we have achieved sticky status! Who would have guessed?
Old Apr 22, 2010 | 04:40 PM
  #196
Off_Road_Teacher
It is nice to see a performance based thread on here, they are too few and far between for my liking. So when I good one comes around, it gets stuck!
Old Apr 22, 2010 | 05:17 PM
  #197
RedTruck-VA
Well my street truck won't see those times. But i did go out to make a couple runs. I found with the OD off and stuck in 2nd gear with a smooth roll on the gas I can go quicker. First run 6.54, 2nd run 6.30 and finally a 6.25. I took all the junk out of the back except my ballast box (100lbs). No more rear end/converter parts and lawn mower. And you thought she was just a cruiser lol. This basically tells me I need to do something for traction to launch harder. I'm happy with this has I see I can go a lot quicker without working on the motor, The traction bars prevent axle hop so I just need less air pressure to begin with, maybe more ballst or sticky tires. I am sure it'll go into 5's without too much work.
Old Apr 22, 2010 | 05:19 PM
  #198
AF_HEMI's Avatar
AF_HEMI
AF, what is the deal with you throwing codes when you do WOT runs? Any luck on finding what the cause is? I saw your thread over on DT about it earlier this morning.
not terribly sure. Its a code I've never heard of, and apparently no one else has either cause I havent gotten any hits on either forum about it. Its not just when WOT. I cleared it last night, and it popped up again while granny drivin it to work this morning.
  #199
SilverBullet08's Avatar
SilverBullet08
I wanna go fast, I wanna go fast
Old Apr 22, 2010 | 05:35 PM
  #200
AF_HEMI's Avatar
AF_HEMI
If you aint first, you're last
