Data Loggers
heres a pic of the times from the superchips after that last run:
did another run, 0-60 logged. fudged up the launch pretty good, and spun the tires too much. you can tell by the drop in time. 6.34
i still dont think its right though. my truck shouldnt be THAT fast with the amount of mods i have.
Your 330ft @61mph @ 6.08sec and your 0-60 is at 6.34 Thats almost 3 tenths of a second difference
Ol Dirty.. Agree with Truckin and your timings considering your great mods are very believeable especially when you doublechecked your tire data. Did you play with the TM percentage (unknown to a 03 forgotten) as discussed with Teach.
I betcha if I put on some 17" P245 Pizza cutters on mine I can get the tires to spin..Ha.
i've havn't really adjusted anything on my tuner ... i'm thinkin it's about time i should actually tune it right.
John, did you actually physically measure your tires to make sure they are 33"? Just asking bc I know that my tires spec out at 33" according to the size but are not actually that tall when I physically measure them. If the size is off that could mess up your times.
in between the 1/4 run, and the 0-60 run, i turned TM from 60% down to 15%. 0-60 time was 3 tenths slower because of the huge amount of wheel spin i got. i sat there and spun for a while. thats probably why its such a difference. and yes i did physically measure my tires. they spec out to 33.8 but physically measure 33 even. so i put 33 into the superchips.
also, speedo is dead on, checked with both gps, and those radar signs on the side of the road.
i will be in fresno this weekend, staying in the country. flat strait roads for miles and miles. im gonna take that opportunity to practice launches, and get a ton of timed runs in.
John, I'm looking forward to what you get. I had a chance to make a couple runs this morning and ran a 6.40 (0-60 MPH) then ran a 6.45 with a touch more wheel spin. It seems to be dialed in to the 6.40 pretty much using the AI. I came home and cleaned the air filter and pulled the TB. The filter was pretty dirty as the truck has been at the paint shop and the TB looks spotless. I used a little high temp sealant when I re-installed it. I'll make a run later today and I hope I get a positive response. I never did feel the TB did anything when I first installed it.
