Data Loggers
Old May 30, 2010 | 12:27 AM
  #591
03MopaRamman's Avatar
03MopaRamman
Tap the Rear Diff with a small ball peen until it goes away (light goes out), kinda like a starter on a Cheby or window motor on a Furd. it's happened twice to me after I have worked in that area. Really only had 3 cans of Beer.
Old May 30, 2010 | 07:10 AM
  #592
RedTruck-VA's Avatar
RedTruck-VA
Tapping on the housing sounds like a cure for a contaminated VSS/tone ring. I have fresh oil in mine, so maybe I'll see if I can just pull the sensor and take a look at it. Thanks,
Old May 30, 2010 | 08:10 AM
  #593
Off_Road_Teacher's Avatar
Off_Road_Teacher
Originally Posted by RedTruck-VA
But it is what we do....... I got a problem with my ABS warning light. I believe it is related to the DSP, so posted it on that thread.
Have you checked on the DSP forum about this? Yours is not the first truck that I have read about that have had an abs light pop while using the DSP. In fact, I had it happen to me when I had the DSP but it went off for me after driving it in reverse for about 100 feet. Maybe you can try that.
Old May 30, 2010 | 11:07 AM
  #594
RedTruck-VA
Teacher, yes I read DSP forum and you are correct, this was a reported problem with DSP DR03 firmware. Suposely DR04 directly addressed this problem and fixed it. My DSP had DR04 firmware installed when this problem came up yesterday. Actually, while loading a tune a few days ago the same thing happened and while backing up (30-40 ft) it went out. Last evening, I installed the original tune back in the truck and updated the firmware to the latest version. This morning I installed the canned 93 tune + wheel hieght. Ran it 1/4 mile, turned it off/on, backed up about 100 feet, and then drove it about 8 miles. I still have the ABS warning light. Oh, lol and tapped on the housing for good luck. I have no codes. The manual says if the HCU is replaced, it has to be flashed using the DRBII tool. I'm wondering if the DSP screwed up my HCU settings. I just don't know enough about this. But I can clearly say the DSP caused this problem and I am not a happy camper.
Old May 30, 2010 | 03:15 PM
  #595
truckin151's Avatar
truckin151
So you updated to the 9r07 crom, you went through the DSP and checked for codes (not the Key fob or AI) and cleared everything? I have never had a problem like that with my DSP just an issue back when they were getting the release for the 9r06 CROM figured out cause I lost all transmission tuning.
Old May 30, 2010 | 03:38 PM
  #596
RedTruck-VA
Truckin, yes I've loaded the 9r07 crom and used the DSP to check for codes. said, "no codes found" and I still went through the erase code steps. Brakes feel the same as before, runs good. Everything feel normal, just have flashing ABS amber warning light.
Old May 31, 2010 | 12:40 PM
  #597
Off_Road_Teacher
Have you contacted someone over at Diablo? Do they have any answers for you?
Old May 31, 2010 | 02:17 PM
  #598
RedTruck-VA
I've posted on the forum with my problem. It has been read by a few folks but no answers yet. Tomorrow I'm at the paint shop probably all day. Maybe Wednesday I'll call.
Old May 31, 2010 | 03:57 PM
  #599
truckin151's Avatar
truckin151
Whats next to be painted?
Old May 31, 2010 | 05:24 PM
  #600
RedTruck-VA
Painting the newly installed roll pan. Hidden hitch and flip license. I didn't like the look of the painted bumper.
