View Poll Results: Have you had good results by Grounding the TB ?
Yes
39
81.25%
No
9
18.75%
Voters: 48. You may not vote on this poll
grounding the TB ???
Old Jan 28, 2012 | 04:36 PM
  #81
08HEMI1500's Avatar
08HEMI1500
I disconnected the battery when I installed the wire.
Old Jan 29, 2012 | 04:38 AM
  #82
rbatshon's Avatar
rbatshon
I do not know if I am imagining or not, but I noticed enhancement in fuel consumption after grounding the TB as well as the whole engine. Will confirm after next fill up and calculate the exact MPG.
Old Jan 29, 2012 | 02:00 PM
  #83
wink2873's Avatar
wink2873
I just did this, and Im surprised to say I did notice a difference in idle, throttle response, and shift firmness. My truck would idle at like 500 rpms at a stop sign before, now it idles right at 650.. rock steady. I can definately tell throttle response is better. But the thing that amazed me the most was how much firmer it shifts. It used to fall flat on its face when doing the 1-2 shift, now its not nearly as bad. still not very good.... but not as bad as it was. I used the 6$ piece of 6 guage battery cable from wal mart for a lawn mower... worked perfect and took 15 minutes.
Old Jan 29, 2012 | 02:46 PM
  #84
adventurer's Avatar
adventurer
Yes its amazing, i can't find any explanation of how that wire also changed the shifting !
Old Jan 29, 2012 | 03:10 PM
  #85
HammerZ71's Avatar
HammerZ71
Yep, I've intentionally been driving the truck more than normal the past few days and at this point I know that besides the obvious rock steady idle, I feel a little bit better throttle response and shift firmness. The difference probably would be more if I was bone stock, but with my custom shifts and the SC, they are pretty firm as it is, so the difference is pretty subtle, but definitely there...
Old Jan 29, 2012 | 04:38 PM
  #86
wink2873's Avatar
wink2873
yea, if you had an 03 with no way to adjust shift firmness, youd be amazed at how much better it shifts. I was actually thinking about spending the money on a sharadon valve body until now. I just wonder how that happens.
Old Jan 29, 2012 | 05:14 PM
  #87
adventurer's Avatar
adventurer
You can add another slight improvement by grounding the engine from the Battery (-) use 0000 AWG wire at least, this way u will also give the tranny some additional grounding ( see the attached pics on post #65 page 7) u will feel a difference after re-setting the PCM
Old Jan 29, 2012 | 05:56 PM
  #88
houseoftoes's Avatar
houseoftoes
I can say that my truck is bone stock and there is a large difference in the way the throttle response is and the shifting is a big difference. My gas mileage dropped (according to my little overhead console, if that means anything) from a solid 13.9 to a 13.5. Ill take the .4 lose any day!
Old Jan 29, 2012 | 07:24 PM
  #89
adventurer's Avatar
adventurer
Yes as Hammer said The difference will be more obvious on a bone stock truck than on a custom tuned truck
Old Jan 29, 2012 | 09:08 PM
  #90
Brandon Anderson's Avatar
Brandon Anderson
After showing signs of going dead for over a month now, my battery finally kicked the bucket this weekend. I decided to try the ground wire out when I was under the hood changing the battery out. Bought 10awg wire and crimped on my own ring connectors. Took about 15min or so, and most of that was uninstalling and reinstalling my CAI. As most here have already mentioned, I noticed the steady idle right away. Since purchasing the truck, I had always thought the idle was shaky, and this was my sole reason for performing this mod. I also noticed that the throttle does seem to respond quicker, but it's not pronounced.
Of course I snapped some pics. Unless you know what you're looking for, you'd hardly notice it's there at all.
