UPDATE!!! INSTALLED MY CAI ***PICS***
Old Apr 30, 2008 | 12:28 AM
HighDuke1911's Avatar
HighDuke1911
Default UPDATE!!! INSTALLED MY CAI ***PICS***
my CAI got delivered to my old adress on tuesday. good thing i went to check today. well, i was following the ebay cai thread in the v6 section since i have an ebay cai. i took out my air box and that big black box on top of my motor that says 5.7L HEMI V8 or whatever. yeah. so then i connected my pipes and my blue tube (as the pictures show). now, since this is the HEMI and not the v6, i noticed a difference of the air hose. im assuming that the HEMI one is the one going IN FRONT of the motor, right? the black tube shown in this pic:
ok. now, that blue hose, i connected it to my CAI like so (i know, i need to clamp it. not driving till i finish the project):
and what do i do with this?????? this is confusing the **** out of me:
thank you guys!!!
Old Apr 30, 2008 | 12:29 AM
HighDuke1911
Default RE: CAI HELP!!!! INSTALL HELP PLEASE *PICS*
oh, in the 3rd pic, im talking about the little sensor. i DID NOT get instructions for installation either.
Old Apr 30, 2008 | 05:24 AM
derricksmash's Avatar
derricksmash
V6 Ram Moderator
it came w/ two pipes, correct? maybe you switched them around, and the "bung" that you plug that sensor into is on the other piece? that is, the one that you have the cone strapped to?
Old Apr 30, 2008 | 08:50 AM
HEMI07's Avatar
HEMI07
that sensor needs to be installed into the pipe. There should be a hole with a rubber grommet in it for the sensor to pop into. Check to see if the pipes are switched around like smash suggested.
Old Apr 30, 2008 | 08:53 AM
RamItOne's Avatar
RamItOne
that sensor should be your mass air sensor, glad to see they didnt forget about your pcv valve...
check out this one for hemis
Old Apr 30, 2008 | 10:27 AM
Horseapples's Avatar
Horseapples
the sensor is the air inlet sensor
Old Apr 30, 2008 | 12:42 PM
bwhite757's Avatar
bwhite757
RamItOne, where did you find that intake???
**EDIT**
Nevermind I found it: http://www.vararam.com
It looks good, but kinda pricey at $399
Old Apr 30, 2008 | 01:35 PM
HighDuke1911
ok, (ill do it when i get home) so i should switch the pipes around and make sure that the pipe with the cone has a rubber thing to stick my sensor into it? i think the switching of the pipes makes sense because of my air tube. i bent it around. maybe it is supposed to go straight. thanks for the tips so far. keep em coming. and does anyone have any detailed pics of their intake that they can share please? thatd be very much appreciated. thank you.
Old Apr 30, 2008 | 02:23 PM
Horseapples
this is my K&N
Old Apr 30, 2008 | 03:32 PM
bwhite757's Avatar
bwhite757
This is my eBay intake... The air sensor is held into place by a rubber grommet. The one that came with my intake wasn't quite right, and I had a hard time getting the sensor to fit snugly into place, so I went to Lowe's and found one that worked... You're tubes are hooked up correctly as far as I can tell, it just looks like you might have lost the black rubber grommet that went into the hole where the sensor is supposed to go...
