Dodge Ram 1500 + STS Turbo System
Old Aug 5, 2009 | 09:03 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Kiss your warranty goodbye
Old Aug 5, 2009 | 09:14 PM
04 HEMI 04's Avatar
04 HEMI 04
if they are past 70k miles so why not put sts if you dont have warranty?
unless they have lifetime power train warranty
Old Aug 5, 2009 | 09:17 PM
Pyro's Avatar
Pyro
I Beat Tetris
Originally Posted by dirtydog
On an STS turbo this is correct. You can't simply say 8psi is cut-off for all Forced induction systems as some eat up more hp than others making them less efficient.
For ex. You could run 8psi on a Procharger and get the same output as a 6psi STS Turbo.
However, any FI system sold on the market is safe for a stock vehcle and will hold up. It's when you get into more boost than what their stock kits provide there will be issue's.
That's what I meant, for an STS on a stock hemi. Although KRC is testing the boosting limits on the 5.9, they haven't played with a stock hemi much. It'd be interesting to see just what the limits are on that engine.
Old Aug 5, 2009 | 09:19 PM
SeVeReDiStOrTiOn
He has an 08...probably still under the bumper to bumper and yea then there's the life powertain.
Old Aug 6, 2009 | 08:07 PM
FrostKing's Avatar
FrostKing
A bit of confusion going on here. The STS Dodge Ram kits do not come with any tuning. You will need a 2 bar MAP sensor, larger fuel injectors, and your choice of custom tuner. ie. CMR, SCT, or various piggyback controllers.
The stock engine will live with 6 psi or up to 8 psi with methanol injection to keep things cool and not detonating. Any higher and the cast aluminum pistons will start breaking apart.
Towing is definitely not a good idea, especially on a stock engine. Boost increases with engine load meaning towing up a hill will cause high boost levels at low RPM. While this provides great torque, the pistons and valves are going to melt.
Old Aug 7, 2009 | 12:07 AM
truckin151's Avatar
truckin151
Frost king - I have seen some of your youtube videos of your truck (assuming this is your truck, which I believe it is) let me say your truck is just sick!!!
http://www.youtube.com/watch?v=2ahXbH1TrVU
Old Aug 10, 2009 | 10:19 PM
Rodri33a's Avatar
Rodri33a
So this system will void the warranty?
Old Aug 10, 2009 | 10:42 PM
ried69's Avatar
ried69
Do these really work on a 2003 Hemi? If so, that would be really cool. And that truck in the video is really sick also.
Old Aug 10, 2009 | 10:49 PM
FrostKing's Avatar
FrostKing
The truck in the video is a 2003 Ram. The dealer voids the warranty, not the turbo, so shop around and make friends.
Old Aug 10, 2009 | 10:58 PM
ried69's Avatar
ried69
Was that engine a bored out Hemi? Because I've been looking for any FI solution that I can. Especially after my brother got a Supercharger on his truck. My truck is a 2003 Hemi, and obviously, a supercharger can't be put on my truck.
