shorties
Old May 9, 2010 | 05:11 PM
Michael0077's Avatar
Michael0077
Default shorties
nearin the end of my DIY performance mods, every other mod i just last mechanical skill for. after a long thought .. decided i'm goin with short tube headers, probably gibson.
my question : how hard are these to self install?
looked up the intructions, got the jist of it down, but when it comes down to actually doing it myself .. will it be worth the headache? or should i just get a shop to do it
edit : cermic or stainless?
Old May 9, 2010 | 05:21 PM
dirtydog's Avatar
dirtydog
Moderate User
nah, it's easy. Do them yourself. My JBA's took me a little over an hour. Just pre-spray the header studs a day or 2 prior. You'll wanna take your fender liners out and work over the tires. Those only have 8 small bolts holing them on. very easy, just have a ziplock baggie handy or a bin for the fenderliner bolts.
Old May 9, 2010 | 05:58 PM
Michael0077
yeah i had to take off those to install my intake (wierd i know)
any other things you can recommend? i figure if it took you an hour it'll take me about six.
Old May 9, 2010 | 06:59 PM
dedogg's Avatar
dedogg
it was easy no problems. On a scale of 1 to 10 (10 being the hardest) I would rate it a 3 or 4.
Old May 9, 2010 | 07:14 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Long tubes are pretty easy to install so shorties should be a breeze.
Old May 10, 2010 | 01:16 PM
Michael0077
should be easier, if i read the **** right shorties don't require welding.
Old May 10, 2010 | 01:38 PM
Shiloh 24's Avatar
Shiloh 24
Shorties (last I knew) were a direct bolt on, no cutting or welding required just tighten up the nuts and bolts and go.
Old May 10, 2010 | 01:46 PM
dirtydog's Avatar
dirtydog
Moderate User
Midlengths are the only headers that require welding, not shorties nor LT's.
Old May 10, 2010 | 02:45 PM
Trendy Rendy's Avatar
Trendy Rendy
do they make long tubes for the 4.7?
Old May 10, 2010 | 03:50 PM
Michael0077
not that i know of. also, if you have superchip 3865 it reccomends you don't get long tube headers. but it says short tube headers are completely fine.
