LED interior and tag ligthts
Old Jul 20, 2010 | 03:30 PM
  #21
bigpappaholt's Avatar
bigpappaholt
Originally Posted by ram man17
In the pics above, is that cool white or warm white?
idk it just said white. i think cool thou.
i havent had any flicker issues, thou did have one smd go out but i think it was because i pushed on it real hard. i did have to put a small resistor on one of the interior lights and one the the leds in my 3rd break bed lights.
i got the 6 smd for the 2 map lights and a 9 smd for the dome, 5 smd for the cargo 3rd break lights and 4 smd for the licence plate lights
Old Jul 22, 2010 | 12:21 PM
  #22
ram man17's Avatar
ram man17
Ok I just put mine in (thanks to you) and they work great except nothing happens when you push the light to individually come on...if I turn on all 3 lights with that side **** they turn on, but if I try pressing on one of the lights with them all on, the one I press turns off...if im being too confusing ill go make a video to show you lol
Old Jul 29, 2010 | 06:06 PM
  #23
BigHorn777's Avatar
BigHorn777
Well don't feel like your the only one confused here. Just got mine today, and installed in like 2 minutes. However they only come on when the doors are open, or if I use the switch on the dash also. When pushing the map lights individually neither of them light up?????? They also have a constant very slight glow to them that don't shut off even when everything else is off??? Anyone else have this issue????
Old Jul 30, 2010 | 07:43 AM
  #24
bigpappaholt
I had the same issue. I installed one resister on the driver side map light and now they don't glow, they come on individually too. ( when truck is off and I try to turn on one map light it does just glow, but with truck on it works) I used 100 ohm 1/2 watt resister.
Old Jul 31, 2010 | 01:21 PM
  #25
Mudhog99's Avatar
Mudhog99
Default recon lights
i put the recon version in the inside and have the same problem...need to install a resistor for the map lights. not really worried about it..just bummed that i cant replace the bulbs for my brake lights. the tech from recon said that dodge has a jacked up harness and pretty much have to replace the whole thing. reverse bulbs work great and the license plate lights as well.
Old Jul 31, 2010 | 11:30 PM
  #26
BigHorn777's Avatar
BigHorn777
Mega black tank, do your lights work fine when the truck is off and you try to turn on your map lights? I want to figure this out before I send them back... I got mine from ebay and they look like this, it is the one with two yellow dots and the speared ends.
http://www.hidxenonlights.com/images/lednotice.jpg
