LED interior and tag ligthts
from these guys, you need three of the 4210-hp6 42mm bulbs for the maps and dome, and two of the WLED-x6 which is a 194 replacement with 6 led bulb cluster for the tag lights.
http://www.superbrightleds.com/cgi-b...2Ffestoon.html
and these fit for the cargo lights, the 921-x9 miniature wedge base bulbs.
So I put some of these lights in my truck today,2 for the map lights and 1 in the dome light. The dome light works perfect but the maps only work when I open the door or turn on the light switch. If I push the map lights to turn them on they both flicker like crazy. Do I need to use a resistor on the maps?
Those ones from superbrights are nice, Ive had them in my truck for a few months now, only thing is they glow a little with the truck running.
where did you buy them from? the ones from superbrights come with the resistors inside the bulb and they just pop right in. Try switching the orientation of the bulbs.
I go the superbright ones from this thread. I try and switch them around and see. Do you know what the number on the ones you are?
Trending Topics
