Should I level it or put a 3inch body lift?
Old Aug 3, 2010 | 09:44 AM
rebel61021's Avatar
rebel61021
that is true, but he did not specify what clearance he wanted and did not say for larger tires.
Old Aug 3, 2010 | 01:15 PM
HammerZ71's Avatar
HammerZ71
and a suspension lift or level with the same size tires increases ground clearance?
Old Aug 3, 2010 | 03:03 PM
rebel61021's Avatar
rebel61021
Yes in the front, A lift or level will raise the truck and give you more ground clearance under the oil pan and Trans.
Old Aug 3, 2010 | 03:08 PM
HammerZ71's Avatar
HammerZ71
Ah, AT THE OIL PAN AND TRANS.... That I'll give you, but what about at the hub which was the lowest point to start with?
I know I'm splitting hairs, but technically the ONLY way to increase over-all ground clearance is to increase tire size...
Old Aug 3, 2010 | 03:14 PM
rebel61021's Avatar
rebel61021
Yes that is true. Thanks Hammer I was not trying to argue with you but I know when I leveled my truck I gained center and bumper ground clearance, It was really noticeable with the grill guard I have on before lifting the front it was only about 4-5 inches from the road now the bottom is close to 7-8 of the ground.
Old Aug 3, 2010 | 05:14 PM
pjordan4477's Avatar
pjordan4477
So to review...Bigger tires for ground clearence. Cheapest way to get there is to Level, which allows for 35s. Just so you know the stock 275/60/R20 is a 33" tire.
