Building a 5.7 liter SINGLE TURBO
Old Sep 14, 2010 | 02:32 PM
  #51
runvs's Avatar
runvs
yeha they r all universal so i know it would work the smt6 has already been used before but they stopped making it and went to the smt8 now, but i just wanted to make sure i wasnt wasting my money you know....i found a smt8 new user kit for 299 shipped so i am gonna buy it i belive.....i need to get a gm 3 bar map sensor or a motarola 2.5 bar and some ford blue 39's and i should be good to tune right ?
Old Sep 14, 2010 | 03:31 PM
  #52
runvs's Avatar
runvs
can you use a micromax superchip and the smt8 together to raise the limiter and speed limiter and trans shifting and use the smt8 to tune for a map and injectors ?
Old Sep 14, 2010 | 08:05 PM
  #53
FrostKing's Avatar
FrostKing
Yes. I am using a 3815 Flashpaq for the above and for data logging. Specifically the knock sensors and LT / ST fuel trims.
Old Sep 14, 2010 | 09:00 PM
  #54
runvs's Avatar
runvs
ok cool my tuner is the first one that came out though, it does the speed limiter and rev, and scans codes along with tranny shifts, so i can do that and the smt8.....thats what i like to hear!!!
do you have any ford 39# injectors or map sensor i can buy off you or know anyone who has some...?
Old Sep 15, 2010 | 01:31 PM
  #55
runvs's Avatar
runvs
sorry stand corrected it does not do tranny stuff, it is the maxmicro 3717 i belive like the very first tuner for 03 hemi.....
Old Sep 15, 2010 | 04:47 PM
  #56
MOusafLRT03's Avatar
MOusafLRT03
Originally Posted by irishcarbomb
extra injector controller
http://www.sdsefi.com/eic.html
also look into megasquirt, i used it on a previous turbo project
i was just thinking the same thing. cause i would love to STS my truck, but also, i wanna do it my way and not dump a load a cash. plus, i could tune for anything....
gotta get everything else done first tho.
Old Sep 15, 2010 | 05:13 PM
  #57
Hahns5.2's Avatar
Hahns5.2
As of yesterday my Dakota is running on Megasquirt, it rocks!
Old Sep 15, 2010 | 07:36 PM
  #58
runvs's Avatar
runvs
yeah im getting ford #39 injectors and the smt8 set up for under 400 shipped for it all.....im gonna use either a gm 3 bar map sensor or a srt4 stock 2.5 bar map....idk yet which ever is cheaper, i got almost everything for the turbo setup except piping and the wastgate and oil pump for the return oil line
Old Sep 15, 2010 | 07:40 PM
  #59
FrostKing's Avatar
FrostKing
The SRT-4 MAP sensor needs to be mounted on a proper machined base while the GM sensor can be mounted anywhere with a 1/8" vacuum line running to it. Get the GM style. (same style that Autometer gauges use)
Old Sep 15, 2010 | 11:42 PM
  #60
runvs's Avatar
runvs
ok kool ill get the gm 3 bar is there any specific one i need to get ?
