Winch In Truck Bed for atv Help??
Old Sep 20, 2010 | 08:43 PM
aidenhardcore's Avatar
aidenhardcore
Default Winch In Truck Bed for atv Help??
So I have an quad that I just got fixed after a year. Its a polaris tail boss 325 and its heavy. Getting into my truck bed is a pain. I need at least 3 people to help me and most of the time its just me with no help. I cant drive it up there with ramps cause it too steep. I was thinking of mounting a winch in the back of the bed so i can just attach the cord to the atv and it pulls it self up . Sounds like a good idea. I dont even know anything about what kind to buy. Just a simple cheap one i guess. I know you guys have atvs and bikes so please chime in. Thanks
Old Sep 20, 2010 | 09:03 PM
jake7's Avatar
jake7
might be easier to mount a light(er) winch to the 4-wheeler...
Old Sep 20, 2010 | 09:32 PM
rebel61021's Avatar
rebel61021
buy a trailer much easier and multi-purpose. I boughgt little 4X8 trailer with a ramp gate for like $500 and have used it for more things than the quad don't know why I didn't buy one sooner.
Old Sep 20, 2010 | 10:04 PM
aidenhardcore
If i were to mount a winch to the atv where would i put the rope on the truck bed to make it work. I have no where to clip it in. So that wouldnt work. and for the tailer. No thank you. I would rather just have the winch and not have a trailer.
Old Sep 20, 2010 | 10:10 PM
jake7's Avatar
jake7
Would a tie down mount that are in the back of most trucks not work to connect to?
Old Sep 20, 2010 | 10:29 PM
aidenhardcore
I was thinking that but I do not know if that would hold. I think it would snap and The tie-downs are only on the side so pulling from the side wouldn't make the atv go up straight. This is none right in the back in the middle.It would be better to mount winch on atv and be easier but with no where to hook clip on bed i cant do that. More help guys. Thanks
Old Sep 20, 2010 | 11:04 PM
Matt99's Avatar
Matt99
I would put the winch on the fourwheeler...I dont know why you are saying it is too high because I put my fourwheeler in mine every once in awhile and mine is a lil higher and has 12in outlaws that literally have less than 1/2in on either side once in
I bought a trailer for $500 which cost less than twice as much as my winch (a good warn winch/mounts is $300) but dont use it for that
you have to remember the angle you are trying to use to pull the fourwheeler up....if you put it up high the bed isnt supported enough to pull the quad up so it would fold in...put it too low and the cable couldnt go strait to the quad, it would be pulling against the tailgate. I say put the winch on the fourwheeler and run a wire from the front two tie downs to each other, then hook the winch cable in the middle and you would be doubling your strength
Old Sep 20, 2010 | 11:21 PM
Matt99's Avatar
Matt99
Old Sep 20, 2010 | 11:24 PM
traker1001's Avatar
traker1001
Why don't you just do what we do and drive the atv up there?
Old Sep 20, 2010 | 11:25 PM
HammerZ71's Avatar
HammerZ71
+1 on putting the winch on the four wheeler, but seriously, you should be able to drive yours right up there. I'm lifted 4" and have 35" tires and drive mine on all the time. You can't be any steeper than I drive up.
The key is to stand up and lean forward as you drive up, just like climbing a very tall grade. When you have most of your upper body weight forward of the handle bars there ain't no way that thing will flip backwards...
