Ways to increase mpgs?
Old Sep 29, 2010 | 10:25 PM
bigslick050's Avatar
bigslick050
Originally Posted by Pyro
Tuner, efan, gears can all help, but there is no mod you can do to your truck that will pay for itself in fuel savings.
THE ONLY MOD you can do that WILL pay for itself in fuel saving are dual e-fans. It is the only mod I have ever gained mileage out of.
Went from 13.2 Hwy to 14.8 hwy overnight due to e-fan install + 180 tstat + coolant flush
Yeah and that is in a 97 2500 HD 4X4
Old Sep 29, 2010 | 11:13 PM
atv1988's Avatar
atv1988
Seriously your doing pretty good my hemi gets around 14 mpg with cat back duals, homemade CAI, and a powerwire with stock size tires... dont complain too much
Old Sep 30, 2010 | 12:34 AM
XtremeOracing's Avatar
XtremeOracing
I am getting about 14mpg with resonator delete and homemade cai. I drive about 20 miles a day, half of them highway miles.
Old Sep 30, 2010 | 06:32 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Originally Posted by ridinghighdodgeguy
Dude get an intake and exhaust from afe. ull get like 4 mpg more! itll pay for itself.
http://www.afeintakestore.com/home.aspx
No offense, but if you believe ANY one mod will net you 4+ mpg then someone has been lying to you.
Old Sep 30, 2010 | 09:51 AM
The Moose's Avatar
The Moose
Lay off the gas pedal. Seriously. It is the single biggest way you can increase mileage. Accelerate slowly, decelerate early and anticipate stop lights and stop signs. Limit your top speed to 55 or 60.
The second biggest way is to lay off the brake pedal. The less you use the brake, the more gas you will save, so drive accordingly.
Braking wastes gas
buy turning the forward motion you generated by burning the gas into useless heat in the brakes.
Also change your air filter, spark plugs, plug wires (if equipped), and oil. Keep the tires inflated, even a little above the normal pressure (still below max printed on tire). Use the lightest oil the owner's manual allows for your engine. Take all the extra crap out of your truck, every pound matters. That will all help mileage, but again, not as much as laying off the go pedal.
Old Sep 30, 2010 | 10:34 AM
MikeHTally's Avatar
MikeHTally
Originally Posted by CardinalsFan11
3 Things you can do:
1. Get a Prius
2. Travel on a Mo-Ped
3. Wait for the Electric Car to come back
Welcome to driving a truck...
4. Always drive downhill
Old Sep 30, 2010 | 10:36 AM
MikeHTally's Avatar
MikeHTally
Originally Posted by The Moose
Lay off the gas pedal. ... Limit your top speed to 55 or 60...
Eeewwwww! Where's the fun in that?
Old Sep 30, 2010 | 10:39 AM
MikeHTally's Avatar
MikeHTally
But it says so - right on the box! Don't forget the extra 75 whp, too.
Old Sep 30, 2010 | 01:07 PM
bartvandenberg's Avatar
bartvandenberg
Best way to increase your MPG is to draft behind big trucks everywhere you go.
Wait in your driveway until a big truck goes by and follow it wherever it goes. Hopefully, its going where you want to go.
I bet you could hit 25mpg if you followed trucks around everywhere...staying within 10 feet of its rear end.
Or..do what they did on mythbusters. Coat your entire truck in clay ( I think they used clay) and cut out divots like a golf ball. They proved it majorly increased your MPG even though you add a lot of weight.
Those are my 2 cents.
Old Sep 30, 2010 | 03:27 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
They also did that show on Mythbusters that really showed no gain from following on big truck other than literally being on his bumper physically which is dangerous
