Dash Cracked!!!
Old Oct 6, 2010 | 08:02 PM
Swoosh6928's Avatar
Swoosh6928
Exclamation Dash Cracked!!!
Has anyone had a problem with the dash cracking? started out as a small crack in the center and has spread from the top of the dash all the way to the windshield..Does anyone have a fix for this other then replacing the dash or putting a cover over it?
Old Oct 6, 2010 | 09:26 PM
Matt99's Avatar
Matt99
negative, a new dash or a dashmat are the only options
Old Oct 6, 2010 | 10:03 PM
rtmtrrdr's Avatar
rtmtrrdr
Welcome to the wonderful world of dodge
Old Oct 6, 2010 | 10:20 PM
dave-o's Avatar
dave-o
happened to me to but mine is on the side, i was hoping it would get hot enough to melt together, but that hasnt happened yet
Old Oct 6, 2010 | 10:21 PM
That1guy's Avatar
That1guy
Mine starting cracking. I have the awesome uncommon blue interior thats impossible to find replacement parts. The piece with the defrost vents is only 180 bucks from the dealer. The actual dash pad on top is about 800 dollars and you have to remove the whole dash to replace.
Since both of mine were cracking I knew was a matter of time. Then when my heater core went i had to remove the dash. Well that top piece with the vents snaps in there. So when you pull on it to unsnap it it breaks. Then dodge attaches the defrost vents to the dash pad so that cause the main piece to crack causing me to throw it in anger it shattered. I was pissed to say the least.
I found a junkyard to send me the entire dash minus the gauges, bags, and controls for 175 and replaced them.
Old Oct 6, 2010 | 11:09 PM
HammerZ71's Avatar
HammerZ71
Almost every 2nd Gen Ram and early 3rd Gen ('02 & some early '03s) has the dash cracking issue. Funny, but most dealerships will tell you "never seen that happen before" when you bring it in to them...
Old Oct 6, 2010 | 11:14 PM
vincent714028's Avatar
vincent714028
There's a place I saw somewhere on the internet that offers new hard plastic oem type dash covers for your truck in oem colors with installation videos for $100-$200. Can't remember the name but do a search. It's out there.
Old Oct 7, 2010 | 07:00 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Knock on wood I have no cracks in my 04
Old Oct 7, 2010 | 11:36 AM
Swoosh6928's Avatar
Swoosh6928
Yeah, I found a few junk yards that have what i need but my concern is getting a dash and going through all that i have to to replace it and have it just crack again.. Thanks for the info guys!!
Old Oct 7, 2010 | 12:39 PM
HammerZ71's Avatar
HammerZ71
Pull a dash from a late '03 or newer and it'll be fine, Chrysler changed OE manufacturer due to the issue in early '03...
