lifted 2wd wtf
Old Oct 13, 2010 | 11:22 PM
  #31
Matt99's Avatar
Matt99
Originally Posted by esai.garza
speaking of lifts...how much would it cost to get a 3 inch lift installed? I've already bought the lift kit...and would it look weird on my 33" A/T or would I needa move up to 35's?
1st of all, dont hijack threads...start a new one or PM someone
Second of all, you gave about the least amount of information possible. Sorry to be an *** but this is the third time ive seen you do this. Anyway, you need to specify your lift. 3in body lift, spacer, spindle? 4x4 or 2wd? What year? What brand lift?
the install depends on the lift type AND your area. Honestly we cannot give you a true answer, but more of a roundabout. Any of the lifts that are only 3inches you can do in your drive way but they can cost quite a bit at a shop. Also, dont forget an alignment unless its a body lift
33s will look fine with 3in of lift. It takes about 2.25in to level a 2wd so plan on buying a 1in-ish block to level out the back if you dont like the So cal look
Old Oct 13, 2010 | 11:41 PM
  #32
Marx's Avatar
Marx
Originally Posted by freestyledude
The main reason you lift a 2wd - Fat chicks can't jump
