bad luck
Old Oct 13, 2010 | 10:25 PM
outcast's Avatar
outcast
Default bad luck
Lets hear the bad luck you have had with ur truck. Me bought my truck from my dad for $11,500 with 77,000 easy miles 3k miles later motor goes out. Cost 4k to fix spend 1,600 on new tires then at 85k miles trany goes out and has to spend 1,200 to fix. Havent even owned the truck for a year and now i think the rearend is going to go out.
Old Oct 13, 2010 | 10:51 PM
RedTruck-VA's Avatar
RedTruck-VA
Yeah, I see why they call you outcast. Boned by your own Dad. Tough family.....
Old Oct 14, 2010 | 06:19 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah not good at all. But at least when you are finished you will have a new truck. It would be better if you have the time and tools to do it all yourself though.
Old Oct 14, 2010 | 09:15 AM
HammerZ71's Avatar
HammerZ71
Engine goes at 80k. Tranny soon after. Rear end going. Sounds to me like Pops wasn't too much for doing fluid changes as these are all prime areas that will drop dead on you for the lack of fluid changes.
Number one reason an engine craps out = not changing fluid enough. Number one reason a transmission craps out = not changing fluid often enough. Number one reason a differential craps out = not changing fluid often enough. See a pattern here?
Of course if it's got the stock LSD in the rear, that'd be a good bet for why it's going out too.
I'd say watch for the radiator to go next as I'd bet it's still got the original fluid in it as well...
Old Oct 14, 2010 | 11:02 AM
Marx's Avatar
Marx
i've had my 05 almost a year and it's been great
Old Oct 14, 2010 | 12:04 PM
Slava's Avatar
Slava
Is this a bad luck?
Old Oct 14, 2010 | 12:24 PM
Marx's Avatar
Marx
Originally Posted by Slava
Is this a bad luck?
nope
its just every post i see from this guy is negative, so maybe it personnel habits and not the truck
