On board Air
Old Oct 15, 2010 | 05:46 PM
Paratrooper's Avatar
Paratrooper
Default On board Air
thinking of purchasing the superflow MV50 and was wondering of location i could mount it on my 08 QCSB 1500, kinda of thinking in the engine bay somewere. would i be correct in assuming the location should be relativity high in the engine bay to protect it from water? i could build a case to protect if from dirt my only concern is if it gets wet would it damage the unit
p.s. not looking ot use it while its submerged
Old Oct 18, 2010 | 04:12 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I roiginally had my Viair 380C in my tool box. Some guys like to mount them on the frame rails. I later added a piece of stainless between my frame rails (under the radiator) and moved my compressor there (needed more room in the tool box). I keep an air hose in the back in case I need it for whatever reason.
There are pics in my signature links
Old Oct 18, 2010 | 04:47 PM
Matt99's Avatar
Matt99
hmm you are talking about submersion so I dont know about low on the frame rails....what about build a splash guard and mount it to the passenger side of the firewall?
Old Nov 3, 2010 | 08:06 AM
Paratrooper
do you think i should add a tank??? i dont have bags and doubt ill be buying any (never know though) and prob wouldn't run impact tools since a tank would be to small.( i could always bring my 6 gallon Bostitch air compressor and plug it into my power inverter) besides that would there really be a benefit to having a tank besides faster tire inflation??
Old Nov 3, 2010 | 04:20 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yes i would add a tank. You can get them cheap and having a stored air supply could be useful.
Old Nov 3, 2010 | 07:11 PM
Paratrooper
well i got the listed compressor on top and ill be getting a tank from viair, should i get a 150 psi relay or an 150...... or should i even get any cus i think the compressor comes with one actually build in....
Old Nov 3, 2010 | 07:18 PM
HammerZ71's Avatar
HammerZ71
Lot of room to mount right behind the front bumper. I know guys with "hidden" winches mounted there, so I'm sure there is room for a compressor...
Old Nov 7, 2010 | 09:48 AM
Paratrooper
Ok last question before i go ahead and buy my setup. what size tank do you recommend?. i was going with a 3 gallon and wanted to run 2/8 hose just in case i use impact tools. i have a 6 gallon air compressor at the hose which i use for shop work and tire changes, you all think 3 gallons would be good? or should i go with a 5 or 7 gallon, just dunno were i would mount such a large tank yano
