lift kit question
Old Oct 20, 2010 | 09:00 AM
bjones51982's Avatar
bjones51982
Default lift kit question
I have a 2004 ram 1500 it is not a 4x4. i wanted some suggestion on a good height to lift my truck and also if i should up my tire size if so how big? last how much does a lift kit typically cost?
Old Oct 20, 2010 | 10:32 AM
Matt99's Avatar
Matt99
its all depending on the height man...and tires adjusted to height
you can do a level, body lift, 4 inch, 6inch....
Old Oct 20, 2010 | 11:45 AM
dirtydog's Avatar
dirtydog
Moderate User
Please look HERE which is located in the Faq section. This will give you an idea of what others are running and what other ideas might peak your interests.
Tire fitment is all dependant on what size lift you want to go with.
Price varies drastically from very cheap body lifts to very expensive suspension lifts.
2wd's are a fairly cheap lift, so you get off pretty easy.
Old Oct 20, 2010 | 12:17 PM
bigmac18's Avatar
bigmac18
6" Fabtech Suspension Lift
325/65r18 Tires (35"x13")
