How do I identify LSD
Old Nov 29, 2010 | 12:37 PM
AJOSSY's Avatar
AJOSSY
Default How do I identify LSD
After reading the threads on LSD clip issues, I am concerned about the truck I recently purchased, how can I tell if I am equipped with LSD?
Old Nov 29, 2010 | 12:49 PM
the_ocho's Avatar
the_ocho
read the tag on the rear end or the paper in your glove box
Old Nov 29, 2010 | 12:58 PM
The Bull's Avatar
The Bull
You could always just hold the break mash the gas and see what happens!
Old Nov 29, 2010 | 01:53 PM
bigdaddyII's Avatar
bigdaddyII
Not true. I have an open diff on my 02, and when I do that both tires spin.
AJOSSY, open your glove box. There is a sticker in there, and it will say something about Chrysler Corporate 9.25 axle, and your gear ratio. If you have LSD, somewhere around that info it will say "anti spin".
Old Nov 29, 2010 | 02:59 PM
MikeHTally's Avatar
MikeHTally
If the glove box sticker is missing, put one rear wheel on slippery, the other on dry. Goose it. If it moves, it has LSD. If the slippery wheel spins, it's a peg-leg. If you punch it, the slippery wheel will spin, LSD or not.
Old Nov 29, 2010 | 03:01 PM
AJOSSY's Avatar
AJOSSY
Default Thank you
Looks like I do not have the LSD so dodged that bullet.
Thanks again!
Old Nov 30, 2010 | 04:30 AM
abarmby's Avatar
abarmby
When you next open your differential cover....look inside for the clutch packs.
100% guarteed you will then know, if you have an LSD or not?
Old Nov 30, 2010 | 06:16 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can also get a VIN sheet from the dealer that will tell you everything that came with your truck
**moved to the 3rd Gen General Section due to no technical issues**
