lift help
Old Dec 2, 2010 | 03:12 PM
HammerZ71's Avatar
HammerZ71
Originally Posted by countryboy17
what lift do you have in yours??
'Weed has a 4x2, whole different ballgame.
IMO go with a 4" suspension lift, the better ones do not raise the CVs significantly. Skyjacker IS about the best 6" kit, but NOBODY has pulled off a 6" kit that doesn't raise the CV angle quite a bit. It's also the only TRUE 6" kit on the market for torsion, IFS front ends. Other 6" kits are actually anywhere from 4.5-5.5" and rely on a torsion bar crank (again lifting the CV angle even more) for the rest of the lift.
Do the 4" in suspension then add your 3" body lift for a total of 7". This will easily clear 37s and although the weight of 37s will still cause premature wear and there is still a chance of CV explosion, it's the strongest setup you can ask for to clear tires larger than 35"...
Old Dec 2, 2010 | 04:20 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
damn hammer, just keep rubbin it in why dont you? My wounds aint never gonna heal.
Old Dec 2, 2010 | 08:10 PM
countryboy17's Avatar
countryboy17
thanks for the advice.Can i get some stronger CVs made.The truck will not be drove much.This is prob. diff. but i had a 1993 toyota with IFS and i went to the max on lift and ran a 38'' tire never no probs. just kinda showing you how much i baby my trucks thanks for all the help,are the dodge front ends just that weak???
Old Dec 3, 2010 | 12:25 AM
freestyledude's Avatar
freestyledude
I do know they're tougher than the older toyota IFS. Tough as those little trucks are they're not made to run really big tires.
Old Dec 3, 2010 | 06:10 AM
HammerZ71's Avatar
HammerZ71
Compared to other full sized, IFS trucks they are no weaker, but still don't compare to a SFA. I've actually seen more GM trucks with broken CVs than I have Rams.
I believe there is one company making a stronger CV, but I can't remember the name, maybe someone else will chime in.
Obviously, if you are doing this on a "pavement queen" the odds of you snapping a front end component is less.
It's your truck, your money. Lift it as high as you want and stick the biggest tires on it you can. We are just letting you know what issues you may run into...
Old Dec 3, 2010 | 06:40 AM
countryboy17
thanks for all the info.I dont want to break anything.Think im going to 4''suspension and 3'' body lift thanks for all the help
