headman long tubes with a mandrel bent 3 inch y into a single 3 inch pipe up along pass. side of motor then to a t-6 flange with a 81mm borg warner t-6 turbo 3 inch outlet and 3 inch v-band to a 3 inch down pipe currently open.....i run a 60mm v-band wastegate mounted right before the turbo flange(open to atmosphere) and then a k&n filter on the turbo to 3 inch intercooler piping with a water to air intercooler and HKS ssqv (mat black) blow off valve. I run the srt4 map sensor with ford 03 cobra #39 lbs injectors ( around a 550cc) and the perfect power smt8 piggy back.
right now its currently being tuned....so idk about full boost at what rpm yet, but from what its doing right now if i even touch the gas more than 1/4 close to 1/2 its start to make boost right over 2400rpm....
pictures are posted (click on link) in the other pages of this thread
tranny has a fresh build on it and i have the line pressure mod with a 3 k stall converter . soon to have a sharadon valve body stage 3 ....and my rear end is forged axles with a detroit locker and 456's
