De-icer wiper fluid
Old Jan 23, 2011 | 02:23 AM
ckapp's Avatar
ckapp
Default De-icer wiper fluid
Anybody use this stuff? My ex gf swears by it but when i check online i get mixed reviews. stuff like "doesn't work" and "gradual paint damage" are some of what i find. I got a pair of the rainx wipers that are supposed to resist ice, plus when i park i'm going to start leaving the wipers elevated so they won't freeze in place. 'course there is always the old tarp over the glass trick for those really bad mornings. which methods do you prefer?
Old Jan 23, 2011 | 08:42 AM
gordie580's Avatar
gordie580
Some De-icers do work.. Prestone is an ok de-icer, The stuff I use is Green, I think it is called Bug juice and that protects up to -25 below. The wiper thing is ok for not having the wipers freeze in place. Depending how cold it is. The rubber can still freeze with the moisure that is still there. I know around here when it gets over -30, a few of us use a peice of carpet that way it will take all the mosiure away from the wipers not to freeze.
Old Jan 23, 2011 | 11:36 AM
fedexgnd's Avatar
fedexgnd
Actually the Green stuff "bug Juice" is good for only 32 degrees above zero. I know first hand. I forgot to switch out in fall and it froze solid. it does work great in summer (it has ammonia in it)
The Orange stuff from rainx is great in winter. rated to -32 below
Old Jan 23, 2011 | 12:37 PM
pitbull24's Avatar
pitbull24
I use the Prestone spray on de-icer; you can somewhat control over spray. Haven't read the warning label recently, but again you're not spraying this driving down the road. Works great in the driveway.
Old Jan 23, 2011 | 07:36 PM
gordie580's Avatar
gordie580
good catch... I use Mr clean De-icer... and bug juice in the summer... they are both green Mr. Clean stuff has yet to freeze up on me in North dakota yet
Mrclean. window cleaner and de-icer
Old Jan 23, 2011 | 07:52 PM
glass3222's Avatar
glass3222
I use the orange stuff from rainx and have not had it freeze yet this year with temps in the single digits here in pa
Old Jan 24, 2011 | 03:30 AM
ckapp's Avatar
ckapp
I think i'll grab a bottle of the spray-on stuff, since my washer reservoir is nearly full anyway. My concern with the washer de-icer is that the sprayers on the hood will freeze over and i wouldn't be able to use when it is needed
Old Jan 24, 2011 | 11:41 AM
stenerson's Avatar
stenerson
I'm using Prestone this year but not impressed. Will go back to using RainX.
Old Jan 24, 2011 | 01:28 PM
dodgeboy1979's Avatar
dodgeboy1979
get a bottle of rainX and put it on your windo direct this also helps with the freezing and clearing of windows.
