Really bad fuel millage
Old Jan 23, 2011 | 12:08 PM
gt4660's Avatar
gt4660
Default Really bad fuel millage
First things first I understand it is a huge truck with a big engine. I do not expect great millage... 08 Megacab 4x4, 5.7. 34k miles
But since I have had it the millage has dropped from 16 on the highway to about 11. I have went up to a 285 tire but I have a superchips and have reprogrammed to the correct size. GPS and speddo are dead on. Oil and filters changed regularly. no engine codes.
Any ideas?
Greg
Old Jan 23, 2011 | 02:50 PM
HammerZ71's Avatar
HammerZ71
Tire size makes a big deal. I went from 235/65/17s on my Grand Cherokee to 265/65/17s and lost a solid 3-4 mpg. You wouldn't think just a 1.5" increase in tire size would have nailed me that much, but it did.
Tread pattern is a major contributor also as a highway tread offers less grip and resistance than an A/T and a lot less than an M/T tire. In my case I went from a soccer mom, passenger car tread to a true A/T tire...
The fact that you are now using winter blend gas ain't helping you either...
Old Jan 24, 2011 | 01:18 AM
BlueHemi's Avatar
BlueHemi
Any ideas?
Greg
Did the drop coincide with your tire change or was it starting to get worse before the change?
Old Jan 24, 2011 | 02:26 AM
freestyledude's Avatar
freestyledude
Is it pulling left/right? Noticing the brake rotors getting hot/ turning blue?
Old Jan 24, 2011 | 08:59 AM
gt4660's Avatar
gt4660
The drop happened long before the tires. Rotors are normal. It had started before i got the superchip programer also. I have tried running no tune, milage tune, 91, and 87 tunes.
Just strange that it has dropped this bad. On my trip to ky it got a high of 13.2 on the computer and a hand checked avg of 12.8.
Old Jan 24, 2011 | 10:53 AM
Dodge_Ram_3500's Avatar
Dodge_Ram_3500
My 08' Did the same thing, I figured i was just driving too much untill I found out the MPG, it went from 18mpg (about 50/50 highway/city) to 12mpg.
Old Jan 24, 2011 | 11:26 AM
Slava's Avatar
Slava
Maybe because of winter blend gasoline? My MPG also dropped without doing any changes in my truck, winter tires + winter gas = drop of 2.5 MPG
Old Jan 24, 2011 | 12:55 PM
Rich 2500's Avatar
Rich 2500
I'd reset the PCM and see if that helps. I wonder if the reset would help with the "Winter blend" fuel change over all?
