Gears?
Old Jan 24, 2011 | 08:26 PM
terracedean's Avatar
terracedean
Default Gears?
how can i tell what gears i have in my truck?
Old Jan 24, 2011 | 08:48 PM
glass3222's Avatar
glass3222
Here are a few way to find out:
1. Look in your glove box. There is probably a white sticker that will say the gear ratio.
2. If there is no sticker in the glovebox, sometimes there is a tag on the rear axle by the passenger side brakes that will indicate the ratio.
3. search on here, there is a website that you can request a build sheet and it will tell you the gear ratio and all options that your truck was built with.
4. Go to you dealer and ask for a build sheet.
5. Drive at a steady speed in overdrive on flat ground and see what your rpm is, then calculate your gear ratio.
Old Jan 25, 2011 | 08:14 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
IMO the build sheet is best because you get to find out everything else you have also
Old Jan 25, 2011 | 03:56 PM
terracedean
ok heres what i have,heavy duty shocks, stabilizer bar, 205MM HD Front Axle, Corporate 9.25 LD Rear Axle, and a 3.92 gear ratio. is all this good? haha what are my gears good for?, im lifting it 6'' next month is this gonna be ok?
Old Jan 26, 2011 | 03:27 PM
roaddog51's Avatar
roaddog51
a quick way to find your gear ratio is to contact your nearest Dodge dealer, with year and last eight numbers of your vin and they can tell you anyting you need to know about your truck...........
Old Jan 26, 2011 | 03:44 PM
terracedean
ya i just looked on my spec sheet. and i just said what gears i had before you posted that
Old Jan 26, 2011 | 04:54 PM
Albertaramfan's Avatar
Albertaramfan
It depends on the tire size you're planning to go with. 3.92 and 4.10 would be good for 35's. A lot of guys switch over to 4.56s for that extra jam
