detroit trutrac lsd
Old Jan 26, 2011 | 09:35 PM
03celicagts's Avatar
03celicagts
Default detroit trutrac lsd
Two ques.
First anybody on here run bigger than 33" tires with this lsd and have no problems.
Second whos some decent shops to order online from??
Exchange rates looking pretty good at the moment, want to take advantage of the high canadian dollar.
Old Jan 26, 2011 | 11:46 PM
HammerZ71's Avatar
HammerZ71
I don't run it, one of the two reasons I did not buy it back when I did my gears and LSD swap is because the shop I chose specifically told me that the DTT would not honor warranty if the unit was run on tires over 33". The other reason was back when I was looking into it, Detroit was in the process of being taken over by Eaton, there was a down time in manufacturing and I simply couldn't find a DTT for the Chrysler 9.25" rear end. So I went with Auburn, an LSD I had used before.
That said, I personally know guys with both 35" and 37" tires who run the DTT and have not reported any issues...
Old Jan 27, 2011 | 01:34 AM
05akram's Avatar
05akram
Talking
I ran mine with 35's with no problems for 2 years. Try 4wheel parts, Summit Racing, Randy's Ring and Pinion. There are lot out there. These places I have had experience with and it was great at each one.
Old Jan 27, 2011 | 07:37 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ive got 36" with the Auburn LSD. I bought mine from a guy on these forums
Old Jan 28, 2011 | 10:20 PM
03celicagts
Yea I know Im flip flopping here, but been doing a ton of reading. Trutrac seems like an awesome product but it states in the manual not for tire dia larger than 32". **** on that.
Hey Hammer or Weed are u guys running the Pro series in the 9.25" chrysler? Cause I was on the Auburn Gear site and they only have the performace series listed for the 9.25" chrysler rear end.
Hammer for yours what friction modifier are u using with the lucas conventional?
Also im keeping the stock gears but is there anything else I should have changed when I have this lsd installed?
Oh well.
Last ques, what supplier did u guys use??
Old Jan 29, 2011 | 06:49 AM
HammerZ71's Avatar
HammerZ71
You don't want the pro series if you use your truck on the street, the bias is too high. That would be for the track only, IMO.
I believe the last fluid change I used a bottle of Ford modifier, but I don't think there is enough difference from brand to brand to matter.
I bought mine from 4 Wheel Parts, they did my gears and price matched the Auburn and offered to install it for free IF I bought it from them and had it done when they did my gears. There ain't a whole lot more work involved to installing a LSD when you are installing gears as well.
You don't need to purchase anything else but the LSD (and fluid for the diff & RTV, obviously)...
Old Feb 4, 2011 | 12:25 AM
03celicagts
A little update. I did some phoning around talked to several different eaton/detroit distributors and I found out u can indeed run up to a 37" or 38" tire with the trutrac. Just to make sure I phoned up eaton differentials and spoke to one of the techs and confirmed. I was told the manual thats on the eaton site currently is actually old spec.
Even spoke with one of the guys at 4 wheel parts they confirmed this. So for anybody else wondering out there...
Old Feb 4, 2011 | 01:16 AM
pcfixerpro's Avatar
pcfixerpro
Yeah I posted about that a few years ago when the issue came up in the 2nd gen section. I still have my email archived (Aug 08) from Scott at Eaton saying the limiting size is 38". You'll be fine.
https://dodgeforum.com/forum/1391782-post28.html
Last edited by pcfixerpro; Feb 4, 2011 at 01:22 AM. Reason: added link for reference
Old Mar 2, 2011 | 11:31 PM
03celicagts
So i got the unit installed, been driving around for a few days now. Cant even tell its there. No whinning sound just nice quiet smooth operation.
However when I tested it out I found a nice straight road with nobody around. The s bound lane covered with hard pack snow and ice, N bound lane nice dry ashpault. Figured perfect time to test her out, I stopped then hit the gas. The tire on the ice started spinning, then slowed up as the tire on the pavement grabbed traction. Worked but i could hear a distinct noise coming from the diff. Are the trutracs supposed to make a whinning sound when they kickin??
Old Mar 3, 2011 | 02:07 AM
05akram's Avatar
05akram
The one I had did make a noise when I was off roading when one of the tires was loaded with the weight and the other started spinning. As soon as I heard it I stopped. So is it normal or a good thing I dont know, but I did experience noise with it at that time. Other wise the Truetrac is SUPER smooth.
