Before I Buy
Old Feb 9, 2011 | 11:04 AM
FlChris's Avatar
FlChris
Default Before I Buy
Before I buy tires and a lift kit on Friday I want to double check on the items, so I don’t buy the wrong things.
My truck is 2006 Dodge Ram 1500 2wd
For a Lift:
Rough County 3” Lift for 02-05 (Got told it will fit on my 06???????)
Or (if doesn’t work)
2” Front lift Springs for 06 dodge 1500 (will it fit 33’s ???)
Tires:
Interco SS-M16
Lt 295 70 17 (Fit My stock Rims 17x 8 Or No ?????)
Here the Measurement
SIZE INTERCO LT295/70R17
NUMBER M16-07R
WEIGHT 72
TREAD PLY 10
SIDE PLY 2
SKID DEPTH 20/32
TREAD WIDTH 10
O.D. 33.5
C.S. 12
REVS/ MILE 638
RIM 17x7.5-10
MAX 80
Thank u
Flchris
Old Feb 9, 2011 | 11:31 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
33" tires with that 06 lifted2-3" will be fine. Just dont forget the alignment
Old Feb 9, 2011 | 11:51 AM
davidonmars's Avatar
davidonmars
33" tires on a stock height would be fine i'm pretty sure if anything all you'd need is a t bar crank
Old Feb 9, 2011 | 08:01 PM
2006RAMHEMI1979's Avatar
2006RAMHEMI1979
No t bars. He has a 2006.
Old Feb 10, 2011 | 10:07 PM
Matt99's Avatar
Matt99
is the RC lift a spindle? and I saw someone say the springs would work but havent had a definite answer
Old Feb 11, 2011 | 09:14 AM
FlChris's Avatar
FlChris
Matt
it isn't the spindles, it is spring and shock kit for a 05 (I was told and asked about it and will fit my truck). And i look at the spindles. It hard to choose what way to go?
Old Feb 11, 2011 | 09:36 AM
Matt99's Avatar
Matt99
why dont you just get spindles then?
Old Feb 15, 2011 | 09:15 AM
FlChris's Avatar
FlChris
K bought the 3" spindles this weekend and found a deal on toyo MT 285 75 17 (34.1) and just run 295 70 17 (33.8). My question now is would i have to put blocks on the rear, so they dont rub or run it stock as it is? And if so 2" block work?
Thank you
Old Feb 15, 2011 | 09:19 AM
cjs4444's Avatar
cjs4444
a 285/75/17 is not a 34.1 tire....just so you know....you may need a 1.5 block in the back.
285/75 - 33.8
295/70 -33.3
315/70 - 34.4
Old Feb 15, 2011 | 11:49 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I dont see where you would need blocks in the rear to not rub as you will not be doing that but you will certainly want it to be leveled
