Drain plug help.
Old Feb 10, 2011 | 04:34 PM
2005 Dodge Ram's Avatar
2005 Dodge Ram
Default Drain plug help.
I have a 2005 Dodge Ram SLT 4.7 liter. My oil drain plug has been rounded off thanks to EZ Lube. I have tried several options to get it off: vice grips, dremel tool and flat head screw driver plus wrench, etc. I am going to try bolt extractors but I'm unsure as to what size I need. What wrench size is needed to remove the drain plug? Any other ideas as far as removing the plug are appreciated.
Old Feb 10, 2011 | 05:53 PM
HammerZ71's Avatar
HammerZ71
I have a set of Craftsman Bolt-Outs I bought for like $15.99. They work great for rounded out heads...
Old Feb 10, 2011 | 06:14 PM
JDG103's Avatar
JDG103
yup i agree with hammer....they do work great
Old Feb 10, 2011 | 06:20 PM
HammerZ71's Avatar
HammerZ71
Yep, IMO there are two things should be in EVERY toolbox to get you out of trouble, a set of Bolt-Outs for bolts and a set of Grab-Its for screws...
You'll spend under $20 on each and save yourself hours of headache.
Old Feb 10, 2011 | 08:50 PM
MikeHTally's Avatar
MikeHTally
Then get a Fumoto valve for it. Great invention.
Old Feb 10, 2011 | 09:21 PM
Busdriver9's Avatar
Busdriver9
I also usually keep a couple cold ones in my tool box...one for accomplished jobs and the other for troubled jobs! but I agree with the Craftsmen Bolt outs....I just tackled the same problem with the wife's car!
Old Feb 11, 2011 | 09:08 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Like you, when we bought my wifes Mini Cooper the oil pan bolt felt like someone put a combo of lok-tite and used an impact gun. Those tools that Hammer shows are what i have and used I bought them years ago and never used them but that ONE time
Irwin makes my set
Old Feb 11, 2011 | 11:20 AM
2005 Dodge Ram
Thanks for all your help. I had to order a new plug so as soon as it arrives, I will attempt to get the bolt off using the aforementioned bolt extractor. I will keep you guys posted.
