Torsion bar adjustment
Old Feb 22, 2011 | 11:42 PM
matthewm2012's Avatar
matthewm2012
Default Torsion bar adjustment
I have a 2007 dodge ram big horn edition and I want to adjust the torsion bars to level out the truck. It's already pretty level I only need to raise the front end a couple of inches or so, but I have a couple of questions.
1) Am I able to adjust the torsion bars this much without buying any extra parts?
2) Do I need to realign the tires after I adjust the torsion bars?
Any other points would be much appreciated!! Thanks!!
Old Feb 23, 2011 | 08:02 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If it is already leveled then why do you want to lift it more?
Is this a 4wd? Because there is a certain point where CV joint angle becomes an issue.
You must always get an alignment after making adjustments to the suspension
Old Feb 23, 2011 | 09:03 AM
HammerZ71's Avatar
HammerZ71
It don't matter if it's a 4x2 or a 4x4, if it's an '07 it's coil over. YOU HAVE NO TORSION BARS...
