Need Help with Rims
Old Feb 25, 2011 | 11:55 AM
Dipndot's Avatar
Dipndot
Default Need Help with Rims
Need some advice on rims that have a -12mm offset, or a little bit more than that, i'm looking for black with with polished aluminum accent. I've checked onlinetires.com, discounttire.com, tirerack.com, and several more sites to try and find them in my bolt pattern, 5-5.5, but the only rims I find in that pattern are +20mm offset which wont work with my 35 inch tires.
THANKS FOR THE HELP
Old Feb 25, 2011 | 04:44 PM
miketrock's Avatar
miketrock
So what is your question or what do you need advice on ?? What are the other specs of the wheels you're looking at or want ? Generally speaking wheels that are : 17" x 9" or 20" x 9" with around 4.5"-4.75" of backspacing with a -12mm offset works good. The -12mm offset sticks the wheels out farther......the +20mm brings them in and tucks them under the truck closer. Others of close or similar specs might work, too..... 17" x 8" works...I think my stock 20" wheels have around 5" or 5.5" of backspacing , but I don't know the offset of them.
Old Feb 25, 2011 | 06:06 PM
nkyhemi's Avatar
nkyhemi
try 4wheelparts.com Go to the wheel section and follow their directions on selecting your rims and that should help you out . Also tryhttp://www.rimsntires.com/specs.jsp this gives a better idea on what your looking at and for.
