Who all uses balancing beads in their tires?
Old Mar 4, 2011 | 07:52 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Default Who all uses balancing beads in their tires?
As the title asks, who all uses balancing beads? My 36s are A/T's and two shops never could get them perfect and always blamed the tires. There is a shop I know that does road force balancing but charges $25 per tire??? WTF??
So anyway, I did some researching and ended up buying about 20oz in balancing beads and a bottle to put them in through the valve stem. The manufacture only calls for 4oz per my size tires. So i spent about $20 in all which I didnt think was bad.
But how well do these work?
Old Mar 4, 2011 | 10:17 AM
Ben D.'s Avatar
Ben D.
I've never heard bad things about them. Only time i've heard not to use them is if you have TPMS sensors.. which luckily for you, you don't. So I would say give them a chance. Worst case scenario you have to have a shop dismount, remove and remount.
very odd that A/T's wouldn't be able to be balanced. I've heard of that with really aggressive mud terrains but not A/T
Old Mar 4, 2011 | 11:03 AM
the_ocho's Avatar
the_ocho
Iv never bothered to balance anything 35 and up. but i may put some of order some for my tires if they work out for you weedahoe
Old Mar 4, 2011 | 11:08 AM
JDG103's Avatar
JDG103
weed what kinda AT tires are u runnin
Old Mar 4, 2011 | 11:49 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Im running Pirelli ATR Scorpions - 325/45/24's
Old Mar 5, 2011 | 09:25 AM
Geezir's Avatar
Geezir
I know two guys in town who have used them. One is running 37's and the other 35's. Neither one has had anything bad to say about it after a couple months.
Old Mar 5, 2011 | 09:32 AM
BadHab1t's Avatar
BadHab1t
weedahoe, Ramstrat just had new 40"s put on his truck and they used em, they were hopping before, now it smooth you just gotta get used to the noise when you stop you can usually hear the beads fall, but other than that they seem to work well....
Old Mar 5, 2011 | 01:53 PM
Marx's Avatar
Marx
this is interesting
Old Mar 5, 2011 | 07:37 PM
JDG103's Avatar
JDG103
personally i wouldnt use them....get the tire shop to do a static balance on your set up, why do you want to get the beads, are your tires vibbing and hwy speeds
Old Mar 5, 2011 | 10:10 PM
Matt99's Avatar
Matt99
Ive had mine balanced twice with no luck. Maybe this is a good answer for it. This is the first ive heard of em
