New to the Forum and have questions
Old Mar 8, 2011 | 12:54 PM
SLTRam's Avatar
SLTRam
Default New to the Forum and have questions
Hello everyone i am new to the dodge forum. I have a 2006 Dodge Ram 1500 2wd with a K&N Cold intake with stock dodge rams (17x8). I bought a 2" Front Lift Kit w/ Pro Comp ES3000 Shocks 2WD from Fat Bob Garage. My question is what size tire can i run with it (33 or 34 or 35 )? I did some research on this site and found an article about lifts & tires and it reads a min 2" lift to run 35" (is it true)? I found alot of 285 70 17 M/T (33") that will fit my stock rim and also found 285 75 17 Nitro A/t (34"). Not really lookin for 35"s.
What size can i run?
thank you
Old Mar 8, 2011 | 01:08 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
We have some awesome tires threads in our FAQs at the top of the section. 35s with a 2: lift on a 2wd might be stuffed and still scrub at some angles. It all depends on the width of the tire and the backspacing on the rim
Old Mar 8, 2011 | 04:54 PM
nussdawg395's Avatar
nussdawg395
Yupp if your going to run 35's you'll need 2 inches of lift and if your using your stock 17's you'll need some spacers in there. Other than that you should be good to go.
Old Mar 8, 2011 | 05:40 PM
Matt99's Avatar
Matt99
ive had rubbing with bad angles. and i have a 2.5" level and 3" body lift.
Old Mar 8, 2011 | 08:28 PM
CaliDodgeRam's Avatar
CaliDodgeRam
Noob with questions who would have ever thought... Kidding welcome to the forum! Pictures of the rig?
