stacks on a hemi.
Old Mar 20, 2011 | 05:20 PM
freestyledude's Avatar
freestyledude
You can do anything you want for looks if your truck is FAST
Old Mar 20, 2011 | 08:55 PM
HemiMoparGuy1981's Avatar
HemiMoparGuy1981
I don't see what the big deal is...The Lil Red Express had them WAY back...
Old Mar 20, 2011 | 10:03 PM
HemiRam1566's Avatar
HemiRam1566
im only 19 if age matters? and the truck isnt slow... hemimoparguy, thats what i mean and now Mr norms is making a lil red xpress package with stacks, thats what initially gave me the idea..
Old Mar 20, 2011 | 10:20 PM
Bent's Avatar
Bent
then you can get some stenciling on the tailgate that says "when I grow up, I want to be a Kenworth".
HemiMoparGuy1981
I saw pics of the Red Xpress you mentioned. Looks pretty cool, but most of the stack is hidden by the bed. I wonder if maybe a Dakota bed and try to flare it out with a dually fender...to make it look a lot more like the lil red express
Old Mar 20, 2011 | 10:21 PM
Marx's Avatar
Marx
if your stack are over 3" you will lose performance and 3" stack are kinda small, i don't mind stacks but the pipes would have to be at least 5" each
i like stacks, keeps the exhaust off stuff your haulling/farm work and good if you muddin, and IMO would only put them on a diesel
Old Mar 20, 2011 | 10:44 PM
slimvela's Avatar
slimvela
i see a 3500 Cummins Mega rollin with stacks all the time...across the back window it reads... "<--Prius Repellent-->" between the stacks...btw, it runs ridiculous 1/4 mile times.
Old Mar 20, 2011 | 10:45 PM
HemiMoparGuy1981
I guess I don't really understand how it could decrease performance...isn't it the point to get rid of exhaust as fast as possible to make room for more?? How do open headers on the strip work then, without a decrease in performance??
Old Mar 20, 2011 | 11:08 PM
Marx's Avatar
Marx
because those engines are built to run that way.
From what i have read stock or near stock hemis need a bit of back pressure to operate reliably, and to retain low end torque
also you need the heat to make the cats work properly
bigger isn't always better
Old Mar 20, 2011 | 11:14 PM
HammerZ71's Avatar
HammerZ71
Because to make it look worth a damn, you'd need decent size piping and with a shorter distance and bigger pipe, the exhaust pulse timing and scavanging would be fu*ked...
And I think the modern Lil Red Express looks like chit, you need the step side bed and woodgrain to pull off the stacks:
