looking at a 2008 ram.got a couple questions
Old Apr 10, 2011 | 12:43 PM
lxman1's Avatar
lxman1
Site Moderator
My 08 Hemi quadcab is averaging 18mpg in mixed driving. It will be even better when the winter blend gas goes away.
Right now my only mods are a K&N drop in filter, Airaid MIT pipe (no effect on mileage), soft TruXedo bed cover and a Diablosport Predator running 93 octane fuel and setting with the MDS turned on.
Due to rigorous testing, I have determined that my Magnaflow cat-back, does outflow the stock set-up quite a bit. Enough, in fact that although it makes more hp upstairs, it actually lost enough backpressure to cost a bit of low end torque and was hurting my mileage by over .5mpg. I removed it to try to pinpoint a bearing noise (front hub bearing) and noticed the MPG increase with no other mod or change in driving habit.
My window sticker says my truck should get 13 city/19hwy. On straight hwy trips, I get 22-24 depending on the terrain.
No full size truck is going to get great mileage. They are heavy and slice thru the wind like high rise building. I can tell you that my Ram has 75 more hp than my 01 F150 5.4L did and gets much better mileage and will out pull it by a bunch.
Ford advertises the high mpg's, but they do not tell you the truck configuration. I am quite sure that the mileage claims are for a std cab, short bed, 2wd lightest available truck with that engine.
I bought my 08 new. The only issues I have had in 45K miles is that both front hub bearings have failed. I am guessing that they got a bad batch of bearings from their supplier because this is not a common issue on trucks under 120K miles. I love the truck, I drive it 72miles round trip to work most days unless my wife is off, then I will drive her 35mpg Caliber
My only real complaint is with the factory shocks. They are way too soft. Bilstiens fixed that problem!!
I see that the link no longer works. Did you buy the truck?
Old Apr 10, 2011 | 03:03 PM
plott hound's Avatar
plott hound
thanks again for the replies fellows.i have not bought the truck,still stringing the salesman along.sounds like a better deal all the time though.
